NANO codes(transmit)
#include <stdint.h>
#include <stdlib.h>
const long interval = 500;
const long intervaldigital = 100;
String inputString = "";
boolean stringComplete = false;
unsigned long pxMillis = 0;
unsigned long digitalMillis = 0;
unsigned long pdigitalMillis = 0;
unsigned long xMillis=0;
unsigned long yMillis=0;
unsigned long zMillis=0;
double bat=0.0;
int count=0;
int bit1=0;
int bit2=0;
int bit3=0;
int bit4=0;
int bit5=0;
int bit6=0;
int bit7=0;
int bit8=0;
int joys=0;
int drvon=0;
inputString.reserve(200);
delay(2000);
Serial.print("+++");
delay(2000);
Serial.print("ATCN");
Serial.print('\r');
delay(2000);
pinMode(8, INPUT_PULLUP);
pinMode(12, OUTPUT);
pinMode(10, OUTPUT);
pinMode(11, OUTPUT);
digitalWrite(10, LOW);
digitalWrite(11, LOW);
digitalWrite(12, LOW);
pinMode(2, INPUT_PULLUP);
pinMode(3, INPUT_PULLUP);
pinMode(4, INPUT_PULLUP);
pinMode(5, INPUT_PULLUP);
pinMode(6, INPUT_PULLUP);
pinMode(7, INPUT_PULLUP);
pinMode(9, INPUT_PULLUP);
xMillis = millis();
digitalMillis= millis();
bat=analogRead(A0)*.02443;
if(bat>9.5){digitalWrite(10, LOW);digitalWrite(11, LOW);digitalWrite(12, HIGH);}
if(bat<9.4999){digitalWrite(10, LOW);digitalWrite(11, HIGH);digitalWrite(12, LOW);}
if(bat<9.0){digitalWrite(10, HIGH);digitalWrite(11, LOW);digitalWrite(12, LOW);}
if (digitalMillis - pdigitalMillis >= intervaldigital)
if(drvon==0){bit1=0;}else{bit1=1;}
if(joys==0){bit2=0;}else{bit2=1;}
if(digitalRead(4)==1){bit3=0;}else{bit3=1;}
if(digitalRead(5)==1){bit4=0;}else{bit4=1;}
if(digitalRead(6)==1){bit5=0;}else{bit5=1;}
if(digitalRead(7)==1){bit6=0;}else{bit6=1;}
if(digitalRead(8)==1){bit7=0;}else{bit7=1;}
if(digitalRead(9)==1){bit8=0;}else{bit8=1;}
pdigitalMillis= digitalMillis;
if (xMillis - pxMillis >= interval)
// count=count+1;
Serial.print("D");
Serial.print(bit1);
Serial.print(bit2);
Serial.print(bit3);
Serial.print(bit4);
Serial.print(bit5);
Serial.print(bit6);
Serial.print(bit7);
Serial.print(bit8);
Serial.print("A");
Serial.print(analogRead(A7));
Serial.print("B");
Serial.print(analogRead(A6));
Serial.print(";");
pxMillis= xMillis;
if (stringComplete)
if(inputString.substring(0,1)=="D"){drvon=1;}
if(inputString.substring(0,1)=="d"){drvon=0;}
if(inputString.substring(1,2)=="J"){joys=1;}
if(inputString.substring(1,2)=="j"){joys=0;}
inputString="";
stringComplete=false;
void serialEvent() {
while (Serial.available()&& stringComplete == false) {
// get the new byte:
char inChar = (char)Serial.read();
// add it to the inputString:
inputString += inChar;
// if the incoming character is a newline, set a flag
// so the main loop can do something about it:
if (inChar == 59) {
stringComplete = true;
MEGA codes
const long intervaldigital = 1000;
int drvon=0;
int joys=1;
String inputString = ""; // a string to hold incoming data
boolean stringComplete = false; // whether the string is complete
int fault=0;
int cc=0;
// initialize serial:
Serial1.begin(115200);
// reserve 200 bytes for the inputString:
// print the string when a newline arrives:
if (stringComplete) {
if(inputString.substring(0,1)=="D" && inputString.substring(inputString.length()-1,inputString.length())==";"){pdigitalMillis=digitalMillis;}
//cc=cc+1;
// Serial.println(cc);
Serial.println(inputString);
inputString = "";
if(drvon==0 && joys==0){Serial1.print("dj;");}
if(drvon==0 && joys==1){Serial1.print("dJ;");}
if(drvon==1 && joys==0){Serial1.print("Dj;");}
if(drvon==1 && joys==1){Serial1.print("DJ;");}
fault=1;
drvon==0
cc=0;
Serial.println("Digital Fault");
SerialEvent occurs whenever a new data comes in the
hardware serial RX. This routine is run between each
time loop() runs, so using delay inside loop can delay
response. Multiple bytes of data may be available.
void serialEvent1() {
while (Serial1.available()) {
char inChar = (char)Serial1.read();
if (inChar == 59) {
I don't think it's codes on the Arduino's thats the issue, because it's always a 60sec. delay before good data I'm thinking a XBEE setting.
Tommy
