I have a problem with a xbee. I defined the IR to 7D0 (2000ms), but it sends a frame to the coordinator way more times than once every two seconds. How can I "fix" this situation?
I have no idea what this means.
(2000ms),
Why do you think that a setting of 700, whatever that means, corresponds to 2 seconds?
How is it broken?
In case you don't know using XCTU you need to write all the values in HEX. 0x7D0 is HEX for 2000.
It's not broken. There's a problem with the device that I need to correct.
You could really just don't post replies if you can't help.
Hi josecoelho,
what series of Xbees r u using? May you post the config of the Xbees?
In fact 0x7D0 is the value for 2000ms Sample rate!
does it send the same value or different value everytime in 2 S?
After a lot of times recovering the xbee, it's now working properly. I just don't know if the problem is fixed or if it's because of the sleeping time.
gueee:
Hi josecoelho,
I'm using series 2 xbees. I had to change from 2 seconds to 1 second because 2 seconds were too much time waiting for new data.
Here's the config on xml: http://pastebin.com/KDCyvuKu.
Arnold_Sweden:
It always sends the same value if I don't change inputs, but it sends data too often.
steinie44:
I Like..... +1 karma for you.
ahah, thanks ![]()
Maybe you should try to test the point to point network and config the DH,DL.
josecoelho:
Sorry, my fault, my eyes where tired of reading all the posts ... :~
further i'm only using series1 Xbees.
Anyway, glad to read that it's working for you!
