XBee is not communicating with stock code from GitHub
I have 2 xbee’s S1 (On explorer boards) hooked up to 2 arduinos.
Xbee Dout to Pin 0 RX on arduino.
Xbee Din to Pin1 TX on arduino.
Gnd to Gnd
Xbee 5v to 5v on Arduino.
Xbees loaded with default settings.
I go to GitHub - andrewrapp/xbee-arduino: Arduino library for communicating with XBee radios in API mode and under examples, Grab the Series1_Tx code example.
 * Copyright (c) 2009 Andrew Rapp. All rights reserved.
 * This file is part of XBee-Arduino.
 * XBee-Arduino is free software: you can redistribute it and/or modify
 * it under the terms of the GNU General Public License as published by
 * the Free Software Foundation, either version 3 of the License, or
 * (at your option) any later version.
 * XBee-Arduino is distributed in the hope that it will be useful,
 * but WITHOUT ANY WARRANTY; without even the implied warranty of
 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 * GNU General Public License for more details.
 * You should have received a copy of the GNU General Public License
 * along with XBee-Arduino.  If not, see <http://www.gnu.org/licenses/>.
#include <XBee.h>
This example is for Series 1 XBee
Sends a TX16 or TX64 request with the value of analogRead(pin5) and checks the status response for success
Note: In my testing it took about 15 seconds for the XBee to start reporting success, so I've added a startup delay
XBee xbee = XBee();
unsigned long start = millis();
// allocate two bytes for to hold a 10-bit analog reading
uint8_t payload[] = { 0, 0 };
// with Series 1 you can use either 16-bit or 64-bit addressing
// 16-bit addressing: Enter address of remote XBee, typically the coordinator
Tx16Request tx = Tx16Request(0x1874, payload, sizeof(payload));
// 64-bit addressing: This is the SH + SL address of remote XBee
//XBeeAddress64 addr64 = XBeeAddress64(0x0013a200, 0x4008b490);
// unless you have MY on the receiving radio set to FFFF, this will be received as a RX16 packet
//Tx64Request tx = Tx64Request(addr64, payload, sizeof(payload));
TxStatusResponse txStatus = TxStatusResponse();
int pin5 = 0;
int statusLed = 11;
int errorLed = 12;
void flashLed(int pin, int times, int wait) {
    for (int i = 0; i < times; i++) {
      digitalWrite(pin, HIGH);
      delay(wait);
      digitalWrite(pin, LOW);
      if (i + 1 < times) {
        delay(wait);
  pinMode(statusLed, OUTPUT);
  pinMode(errorLed, OUTPUT);
  xbee.setSerial(Serial);
   // start transmitting after a startup delay.  Note: this will rollover to 0 eventually so not best way to handle
    if (millis() - start > 15000) {
      // break down 10-bit reading into two bytes and place in payload
      pin5 = analogRead(5);
      payload[0] = pin5 >> 8 & 0xff;
      payload[1] = pin5 & 0xff;
      xbee.send(tx);
      // flash TX indicator
      flashLed(statusLed, 1, 100);
    // after sending a tx request, we expect a status response
    // wait up to 5 seconds for the status response
    if (xbee.readPacket(5000)) {
        // got a response!
        // should be a znet tx status
    	if (xbee.getResponse().getApiId() == TX_STATUS_RESPONSE) {
    	   xbee.getResponse().getTxStatusResponse(txStatus);
    	   // get the delivery status, the fifth byte
           if (txStatus.getStatus() == SUCCESS) {
            	// success.  time to celebrate
             	flashLed(statusLed, 5, 50);
            	// the remote XBee did not receive our packet. is it powered on?
             	flashLed(errorLed, 3, 500);
    } else if (xbee.getResponse().isError()) {
      //nss.print("Error reading packet.  Error code: ");
      //nss.println(xbee.getResponse().getErrorCode());
      // or flash error led
      // local XBee did not provide a timely TX Status Response.  Radio is not configured properly or connected
      flashLed(errorLed, 2, 50);
and upload it to Arduino 1.
I grab Series1_Rx code
#include <XBee.h>
This example is for Series 1 XBee (802.15.4)
Receives either a RX16 or RX64 packet and sets a PWM value based on packet data.
Error led is flashed if an unexpected packet is received
XBee xbee = XBee();
XBeeResponse response = XBeeResponse();
// create reusable response objects for responses we expect to handle
Rx16Response rx16 = Rx16Response();
Rx64Response rx64 = Rx64Response();
int statusLed = 11;
int errorLed = 12;
int dataLed = 10;
uint8_t option = 0;
uint8_t data = 0;
      delay(wait);
        delay(wait);
  pinMode(dataLed,  OUTPUT);
  // start serial
  flashLed(statusLed, 3, 50);
// continuously reads packets, looking for RX16 or RX64
    xbee.readPacket();
    if (xbee.getResponse().isAvailable()) {
      // got something
      if (xbee.getResponse().getApiId() == RX_16_RESPONSE || xbee.getResponse().getApiId() == RX_64_RESPONSE) {
        // got a rx packet
        if (xbee.getResponse().getApiId() == RX_16_RESPONSE) {
                xbee.getResponse().getRx16Response(rx16);
        	option = rx16.getOption();
        	data = rx16.getData(0);
                xbee.getResponse().getRx64Response(rx64);
        	option = rx64.getOption();
        	data = rx64.getData(0);
        // TODO check option, rssi bytes
        flashLed(statusLed, 1, 10);
        // set dataLed PWM to value of the first byte in the data
        analogWrite(dataLed, data);
      	// not something we were expecting
        flashLed(errorLed, 1, 25);
and put that on the second arduino.
I hook up the LED’s to the respective pins. Turn on. And It fails.
The Error LED will flash.
I get Error. flashLed(errorLed, 2, 50); So I reconfigure both Xbee’s into API mode (AP[1])
Nah. I get flashLed(errorLed, 3, 500); on both ends.
I have spent the past 8 hours trying to get this to work, with every possible combination of AP, API, API2 w/PPP settings. Cordinator vs End device. I have entered in DL/DH Desination addresses. I have set these to Broadcast (FFFFFFFF) or 0. I have check on forum posts all day long. I have read, and re-read over the git-hub post. Only config they mention is to have it in API2 mode. But that fails too.
I don’t know what else to do.
Yes I have gone to defaults. Yes I can get the Xbee’s to talk to the arduinos with basic If Serial then Write to Xbee, if Xbee, write to serial code loops.
Yes I sometimes can see the data using XCTU’s terminal window. (Depending on what setting I have it at)
Yes I have tried sending commands, and hex packets from XCTU. That has failed 99% of the time.
I am out of options and google search results.
Can anyone help?
The default settings are crap. You MUST assign values to DL and MY. MY on one must be DL on the other.
