How can i realize that network (attached to Pic.docx) efficiently? Which one of thoso nodes should be coordinator,router or end device?Which topology i can make?(tree,mesh,star etc.?)According to your solution which details must be taken acoount?If replyi,id be so happy.From now thanks
Why are only 2 and 4 and 3 and 4 sharing RSSI data? Do you have a clue how useless RSSI data is as a measure of distance?
RSSI measurements are essential for triangulation.
The only one you can make is mesh. That's all that the Series 2 (mesh network) models support.
How can i do mesh network in here?Can you give some details?Does it require extra software in XCTU? Can point to multipoint be another solution.(Node 4 coord===>Node 1 Router (point)===>Node 2,3(multipoints).Look forward to your reply.
Forget it. RSSI is not even a rough order of magnitude related to distance.
Assign one XBee the role of coordinator. Assign the others router or end device roles (usually router is preferred). Turn them on - instant mesh network.
No, not really. That involves broadcast mode, which is slow.
