XBee Powering on through Serial line
I have my Arduino connected to an Xbee. (not with an Xbee shield) I also have the Arduino control the power going to the Xbee to save power. I notice though when the Arduino disconnects the ground to the Xbee, The Xbee still lights up but dimmer. Will putting some kind of a resistor on the Serial lines fix this?
i think there must be a capacitor keeping it lit.
what happens when you remove power wire instead of the ground?
XBees don't light up. ???
Also, XBees are 3.3V and Arduino are 5V.
I should have mentioned I am using this http://www.parallax.com/tabid/768/ProductID/691/Default.aspx
arduinoPi:
How are you doing that?
Porting signals to an unpowered device is generally undesirable. In this case, some of the XBee circuits are finding Ground through Dout/Din.
Yeah, if you're gonna switch the power to an external device, and you do it
by the gnd lead, then the signal leads are still live and you get a sneak
pathway for power through them. If you configure the Arduino output
pins as inputs when you power down the the adaptor, it should work.
Could I put some type of resistor on the serial lines to limit power? I do like and will try the idea of turning the serial lines to inputs.
