i have a remote control car im using two xbees to control one as router and one as cordinator. i interested in what everyone one thinks the best settings would be to have the fastest communication? i can post my arduino code if needed
There is a baud rate that the Arduino uses to talk to the XBee. Faster is, obviously, better.
There is a baud rate that one XBee uses to talk to the other XBee(s). Faster is, obviously, better.
There are addressing modes involved in one XBee talking to another XBee. Using broadcast mode is slow. Obviously, you don't want to use that mode.
There is a baud rate that the second XBee uses to talk to the second Arduino. Faster is, obviously, better.
Then there is the matter of how much data you send, and when you send it. Sending more data, obviously, takes longer.
Only if you want to. If hand-waving answers are fine, you don't need to.
thank you paul. i came across an old post where you talked about the DH, Dl matching the SH,SL on both and i made those changes. i have one as cordinator and one as router i change the baud rate back to 9600 it was set on 57600 but seems to run better on 9600.
Can I send information back to the to xbee?
To the XBee? Or through the XBee? The answer to both is yes. How it is done is different.
i want to send info to the xbee on the car then get a return response to verify its still connected
merkzilla:
As opposed to getting a reply from the Arduino that the XBee is connected to?
Yes I'm sorry for not specifying. I would like to send it through the xbee to the arduino then back to the other arduino through the xbee.
merkzilla:
So, what is the problem?
How are the XBees connected to the Arduinos?
I guess I want to know if I just serial read on the tx side like I do on the rc car side for any serial print from the car?
merkzilla:
Yes, assuming that the car side uses print() or write() to send data.
im having some trouble here i cant seem to get a response from the arduino in the car and also when i push "start" it serial prints "sending start" but my lcd does not clear it looks like its trying to lcd print "no connection push start" and also "connecting please wait" at the same time. but my main issue is the comunication between the two. i know on my micro that ist he controller i had to use Software serial so im assuming id still have to use that when serial reading.
// Receive with start- and end-markers combined with parsing
#include <Servo.h>
Servo SteerServo, MotorServo, CamServoC, CamServoD;
const byte numChars = 32;
char receivedChars[numChars];
char tempChars[numChars];
char messageFromTX[numChars] = {0};
int ServoA = 0;
int ServoB = 0;
int ServoC = 0;
int ServoD = 0;
boolean newData = false;
boolean Connection = false;
CamServoC.attach(5);
SteerServo.attach(6);
MotorServo.attach(7);
//Enter data in this style <text,12,24.7>
if(Connection == false)
recvWithEndMarker();
CheckConnection();
else{
recvWithStartEndMarkers();
if (newData == true) {
strcpy(tempChars, receivedChars);
// this temporary copy is necessary to protect the original data
// because strtok() replaces the commas with \0
parseData();
delay(10);
showParsedData();
movement();
newData = false;
void recvWithStartEndMarkers() {
static boolean recvInProgress = false;
static byte ndx = 0;
char startMarker = '<';
char endMarker = '>';
char rc;
while (Serial.available() > 0 && newData == false) {
rc = Serial.read();
Serial.print(rc);
if (recvInProgress == true) {
if (rc != endMarker) {
receivedChars[ndx] = rc;
ndx++;
if (ndx >= numChars) {
ndx = numChars - 1;
else {
receivedChars[ndx] = '\0'; // terminate the string
ndx = 0;
newData = true;
else if (rc == startMarker) {
recvInProgress = true;
void parseData() {
// split the data into its parts
char * strtokIndx; // this is used by strtok() as an index
strtokIndx = strtok(tempChars,","); // get the first part - the string
strcpy(messageFromTX, strtokIndx); // copy it to messageFromPC
strtokIndx = strtok(NULL, ","); // this continues where the previous call left off
ServoA = atoi(strtokIndx); // convert this part to an integer
ServoB = atoi(strtokIndx); // convert this part to a float
void showParsedData() {
Serial.print(ServoA);
Serial.print(", ");
Serial.println(ServoB);
void movement(){
MotorServo.write(ServoA);
SteerServo.write(ServoB);
void CamMovement(){
CamServoC.write(ServoC);
void CheckConnection() {
if(receivedChars == "start"){
Serial.print(receivedChars);
Connection = true;
else{
return;
void recvWithEndMarker() {
char endMarker = '\n';
char rc;
// if (Serial.available() > 0) {
while (Serial.available() > 0) {
rc = Serial.read();
Serial.print(rc);
ndx++;
ndx = numChars - 1;
else {
ndx = 0;
micro/controller/xbee cordinator
#include <SoftwareSerial.h>
SoftwareSerial Fido(4, 5); // RX, TX
#include <Servo.h>
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
#include <PS2X_lib.h> //for v1.6
#define PS2_DAT 9 //14
#define PS2_CMD 11 //15
#define PS2_SEL 10 //16
#define PS2_CLK 12 //17
//#define pressures true
#define pressures false
//#define rumble true
#define rumble false
char receivedChars[numChars]; // an array to store the received data
int LYVALUE;
int LXVALUE;
int oldLYvalue;
int oldLXvalue;
int RYVALUE;
int RXVALUE;
int oldRYvalue;
int oldRXvalue;
PS2X ps2x;
int error = 0;
byte type = 0;
byte vibrate = 0;
Fido.begin(9600);
delay(300); //added delay to give wireless ps2 module some time to startup, before configuring it
lcd.begin (16, 2);
lcd.clear();
lcd.setBacklight(HIGH);
lcd.setCursor(0, 0);
lcd.print("Activating Fido!");
lcd.setCursor(0, 1);
lcd.print("****************");
//setup pins and settings: GamePad(clock, command, attention, data, Pressures?, Rumble?) check for error
ps2x.config_gamepad(PS2_CLK, PS2_CMD, PS2_SEL, PS2_DAT, pressures, rumble);
if (Connection == false) {
lcd.clear();
lcd.setCursor(1, 0);
lcd.print("No Connection!");
lcd.setCursor(3, 1);
lcd.print("Push Start");
ps2x.read_gamepad(false, vibrate);
if (ps2x.Button(PSB_START))
lcd.clear();
lcd.print("...Connecting...");
lcd.print("Please Wait");
Serial.println("start");
Fido.println("start");
CheckConnection();
return;
else { //DualShock Controller
ps2x.read_gamepad(false, vibrate); //read controller and set large motor to spin at 'vibrate' speed
if (ps2x.NewButtonState())
{ //will be TRUE if any button changes state (on to off, or off to on)
if (ps2x.Button(PSB_L3))
Serial.println("L3 pressed");
Fido.println("L3 pressed");
// circle button///////////////
if (ps2x.ButtonPressed(PSB_CIRCLE))
Serial.println("Circle just pressed");
Fido.println("Circle just pressed");
//X button/////////////////////////////////////////
if (ps2x.ButtonPressed(PSB_CROSS))
Serial.println("X just pressed");
Fido.println("X just pressed");
if (ps2x.ButtonReleased(PSB_CROSS))
Serial.println("X just released");
Fido.println("X just released");
//Square button///////////////////////////////////
if (ps2x.ButtonReleased(PSB_SQUARE))
Serial.println("Square just released");
Fido.println("Square just released");
if (ps2x.ButtonPressed(PSB_SQUARE))
Serial.println("Square just pressed");
Fido.println("Square just pressed");
//Stick Values
LYVALUE = ps2x.Analog(PSS_LY);
LYVALUE = map(LYVALUE, 0, 255, 130, 45);
LXVALUE = ps2x.Analog(PSS_LX);
LXVALUE = map(LXVALUE, 0, 255, 39, 120);
RYVALUE = ps2x.Analog(PSS_RY);
RYVALUE = map(RYVALUE, 0, 255, 0, 180);
RXVALUE = ps2x.Analog(PSS_RX);
RXVALUE = map(RXVALUE, 0, 255, 0, 180);
delay(10);
if (LXVALUE != oldLXvalue || LYVALUE != oldLYvalue) {
Serial.print("<");
Serial.print("LXYValues");
Serial.print(",");
Serial.print(LYVALUE, DEC);
Serial.print(",");
Serial.print(LXVALUE, DEC);
Serial.println(">");
Fido.print("<");
Fido.print("LXYValues");
Fido.print(",");
Fido.print(LYVALUE, DEC);
Fido.print(",");
Fido.print(LXVALUE, DEC);
Fido.println(">");
oldLXvalue = LXVALUE;
oldLYvalue = LYVALUE;
if (RXVALUE != oldRXvalue || RYVALUE != oldRYvalue) {
Serial.print("-");
Serial.print("RXYValues");
Serial.print(",");
Serial.print(RYVALUE, DEC);
Serial.print(",");
Serial.print(RXVALUE, DEC);
Fido.print("-");
Fido.print("RXYValues");
Fido.print(",");
Fido.print(RYVALUE, DEC);
Fido.print(",");
Fido.print(RXVALUE, DEC);
Fido.println(">");
oldRXvalue = RXVALUE;
oldRYvalue = RYVALUE;
delay(50);
char rc;
while (Fido.available() > 0 && newData == false) {
rc = Fido.read();
Serial.print(rc);
ndx++;
ndx = numChars - 1;
else {
ndx = 0;
newData = true;
Serial.println(receivedChars);
if (receivedChars == "start") {
lcd.clear();
lcd.print("Connected!");
lcd.print("Enjoy!");
Connection = true;
else {
return;
