Xbee Problem----> Impossible to change adress
Hello everybody...
I am trying to have two Xbees comunicating...in order to do so, according to Tom Igoe's book, the two shields must have same DH and ID, which i was able to change easily...this is what i did:
+++ ----->ok
ATDH0---->OK
now, always according to Tom Igoe's, first radio should have it's own adress (MY) and as destination adress (DL) the MYadress of the other radio:
radio 1: MY =1234 DL = 5678
radio 2: MY =5678 DL = 1234
Now here are the problems...
First the default setting for the MY should be 0, instead i get FFFE...Why?...on the guide of this site it says that valid values should be 0 - 0xFFFF ??? what does it means?
Second it is impossible to change that value!!!?? it just keep saying ERROR...and on squidbee wiki example http://www.libelium.com/squidbee/index.php?title=How_to_set_XBee_parameters it change the adress as easily as the other paramters...
Where is the problem??? am I missing something?
Thanks for the help
I found this topic in wich it seemed that Dieter had the same problem, but i don't understand were the solution is...
here is the link to the post http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1214566904
User Cairn says he posted a tutorial but the page is no longer there...It says error
I just replied to your post on the other thread. Does this link work for you? http://www.humboldt.edu/~cm19/XBee%20setup.pdf
