I am trying to receive the data in API mode. but i got some weird characters instead of actual data.
This is my code. please tell me where i am going wrong. any help will be appreciated.
#include <XBee.h>
#include <SoftwareSerial.h>
XBee xbee = XBee();
XBeeResponse response = XBeeResponse();
// create reusable response objects for responses we expect to handle
ZBRxResponse rx = ZBRxResponse();
// Define NewSoftSerial TX/RX pins
// Connect Arduino pin 2 to Tx and 3 to Rx of the XBee
// I know this sounds backwards, but remember that output
// from the Arduino is input to the Xbee
#define ssRX 2
#define ssTX 3
SoftwareSerial nss(ssRX, ssTX);
// start serial
// and the software serial port
nss.begin(9600);
// now that they are started, hook the XBee into
// Software Serial
xbee.setSerial(nss);
// I think this is the only line actually left over
// from Andrew's original example
Serial.println("starting up yo!");
// doing the read without a timer makes it non-blocking, so
// you can do other stuff in loop() as well.
xbee.readPacket();
// so the read above will set the available up to
// work when you check it.
if (xbee.getResponse().isAvailable()) {
// got something
Serial.print("Frame Type is ");
// Andrew call the frame type ApiId, it's the first byte
// of the frame specific data in the packet.
Serial.println(xbee.getResponse().getApiId(), HEX);
// if (xbee.getResponse().getApiId() == ZB_RX_RESPONSE) {
// got a zb rx packet, the kind this code is looking for
// now that you know it's a receive packet
// fill in the values
xbee.getResponse().getZBRxResponse(rx);
// this is how you get the 64 bit address out of
// the incoming packet so you know which device
// it came from
Serial.print("Got an rx packet from: ");
XBeeAddress64 senderLongAddress = rx.getRemoteAddress64();
print32Bits(senderLongAddress.getMsb());
Serial.print(" ");
print32Bits(senderLongAddress.getLsb());
// this is how to get the sender's
// 16 bit address and show it
uint16_t senderShortAddress = rx.getRemoteAddress16();
Serial.print(" (");
print16Bits(senderShortAddress);
Serial.println(")");
// The option byte is a bit field
if (rx.getOption() & ZB_PACKET_ACKNOWLEDGED)
// the sender got an ACK
Serial.println("packet acknowledged");
if (rx.getOption() & ZB_BROADCAST_PACKET)
// This was a broadcast packet
Serial.println("broadcast Packet");
Serial.print("checksum is ");
Serial.println(rx.getChecksum(), HEX);
// this is the packet length
Serial.print("packet length is ");
Serial.print(rx.getPacketLength(), DEC);
// this is the payload length, probably
// what you actually want to use
Serial.print("data payload length is ");
Serial.println(rx.getDataLength(),DEC);
// this is the actual data you sent
Serial.println("Received Data: ");
for (int i = 0; i < rx.getDataLength(); i++) {
print8Bits(rx.getData()[i]);
Serial.print(' ');
// and an ascii representation for those of us
// that send text through the XBee
for (int i= 0; i < rx.getDataLength(); i++){
Serial.write(' ');
if (iscntrl(rx.getData()[i]))
Serial.write(' ');
Serial.write((char)rx.getData()[i]);
Serial.write(' ');
// So, for example, you could do something like this:
handleXbeeRxMessage(rx.getData(), rx.getDataLength());
// I commented out the printing of the entire frame, but
// left the code in place in case you want to see it for
// debugging or something
Serial.println("frame data:");
for (int i = 0; i < xbee.getResponse().getFrameDataLength(); i++) {
print8Bits(xbee.getResponse().getFrameData()[i]);
Serial.print(' ');
for (int i= 0; i < xbee.getResponse().getFrameDataLength(); i++){
Serial.write(' ');
if (iscntrl(xbee.getResponse().getFrameData()[i]))
Serial.write(' ');
Serial.write(xbee.getResponse().getFrameData()[i]);
Serial.write(' ');
else if (xbee.getResponse().isError()) {
// some kind of error happened, I put the stars in so
// it could easily be found
Serial.print("************************************* error code:");
Serial.println(xbee.getResponse().getErrorCode(),DEC);
else {
// I hate else statements that don't have some kind
// ending. This is where you handle other things
void handleXbeeRxMessage(uint8_t *data, uint8_t length){
// this is just a stub to show how to get the data,
// and is where you put your code to do something with
// it.
for (int i = 0; i < length; i++){
Serial.print((char)data[i]);
// these routines are just to print the data with
// leading zeros and allow formatting such that it
// will be easy to read.
void print32Bits(uint32_t dw){
print16Bits(dw >> 16);
print16Bits(dw & 0xFFFF);
void print16Bits(uint16_t w){
print8Bits(w >> 8);
print8Bits(w & 0x00FF);
void print8Bits(byte c){
uint8_t nibble = (c >> 4);
if (nibble <= 9)
Serial.write(nibble + 0x30);
Serial.write(nibble + 0x37);
nibble = (uint8_t) (c & 0x0F);
if (nibble <= 9)
