XBee Rx response different from XBee Tx
Dear Friends,
In this opportunity despite of the “xbee pro s2b” (XBP24B7PIT) modules can communicate each other, the Rx value (0 - 1023) is different from the Tx analog value, additionally, the Rx value does not change although the Tx value changes.
Both modules are configured in API 2 (one as coordinator and the other as end device), have the same PAN ID, and so forth.
In order to reach this purpose I am using arduino boards UNO R3, xbee shields of DFRobot v1.4, and a Seedstudio relay shield.
The main purpose of the sketch is to control a relay if the analog value is in between a definite range, but by the moment I am trying to visualize the Rx value in the monitor to confirm the that Tx and Rx will be the same.
Sincerely I appreciate very much your help.
Thanks in advance.
Here the codes:
#include <XBee.h>
#include <Wire.h>
XBee xbee = XBee();
XBeeResponse response = XBeeResponse();
// create reusable response objects for responses we expect to handle
ZBRxResponse rx = ZBRxResponse();
ModemStatusResponse msr = ModemStatusResponse();
int statusLed = 11;
int errorLed = 12;
int dataLed = 13;
int sensorValue = 0;        // value read from the rx
void flashLed(int pin, int times, int wait) {
    for (int i = 0; i < times; i++) {
      digitalWrite(pin, HIGH);
      delay(wait);
      digitalWrite(pin, LOW);
      if (i + 1 < times) {
        delay(wait);
  pinMode(statusLed, OUTPUT);
  pinMode(errorLed, OUTPUT);
  pinMode(dataLed,  OUTPUT);
  // start serial
  xbee.begin(Serial);
  flashLed(statusLed, 3, 50);
// continuously reads packets, looking for ZB Receive or Modem Status
    xbee.readPacket();
    if (xbee.getResponse().isAvailable()) {
      // got something
      if (xbee.getResponse().getApiId() == ZB_RX_RESPONSE) {
        // got a zb rx packet
        // now fill our zb rx class
        xbee.getResponse().getZBRxResponse(rx);
        if (rx.getOption() == ZB_PACKET_ACKNOWLEDGED) {
            // the sender got an ACK
            flashLed(statusLed, 10, 10);
            // we got it (obviously) but sender didn't get an ACK
            flashLed(errorLed, 2, 20);
      } else if (xbee.getResponse().getApiId() == MODEM_STATUS_RESPONSE) {
        xbee.getResponse().getModemStatusResponse(msr);
        // the local XBee sends this response on certain events, like association/dissociation
        if (msr.getStatus() == ASSOCIATED) {
          // yay this is great.  flash led
        } else if (msr.getStatus() == DISASSOCIATED) {
          // this is awful.. flash led to show our discontent
          flashLed(errorLed, 10, 10);
          // another status
          flashLed(statusLed, 5, 10);
      	// not something we were expecting
        flashLed(errorLed, 1, 25);
    } else if (xbee.getResponse().isError()) {
      //nss.print("Error reading packet.  Error code: ");
      //nss.println(xbee.getResponse().getErrorCode());
     // read the analog in value:
  sensorValue = analogRead(rx.getData(0));
   // print the results to the serial monitor:
  Serial.print("sensor = ");
  Serial.print(sensorValue);
  // wait 50 milliseconds before the next loop
  // for the analog-to-digital converter to settle
  // after the last reading:
#include <avr/sleep.h>
#include <Wire.h>
#include "Sodaq_DS3231.h"
#include <XBee.h>
  Sends a ZB TX request with the value of analogRead(pin0) and checks the status response for success
// create the XBee object
XBee xbee = XBee();
uint8_t payload[] = { 0, 0 };
// SH + SL Address of receiving XBee
XBeeAddress64 addr64 = XBeeAddress64(0x0013A200, 0x4098791E);
ZBTxRequest zbTx = ZBTxRequest(addr64, payload, sizeof(payload));
ZBTxStatusResponse txStatus = ZBTxStatusResponse();
int statusLed = 13;
int errorLed = 12;
    delay(wait);
      delay(wait);
char weekDay[][4] = {"Sun", "Mon", "Tue", "Wed", "Thu", "Fri", "Sat" };
const int inputPin = 2;
const int analogInPin = A0;  // Analog input pin that the sensor is attached to
int sensorValue = 0;        // value read from the sensor
int outputValue = 0;        // value output to the sensor (analog out)
const int powerPin =  8;      // the number of the power pin
const uint8_t horaInicio = 9; // set the starting hour
const uint8_t horaFin = 18;  // set the finish hour
volatile boolean flag;
  xbee.setSerial(Serial);
  pinMode (inputPin, INPUT_PULLUP);
  goToSleep();
  Wire.begin();
  rtc.begin();
  pinMode(powerPin, OUTPUT);
void loop ()
  if (flag)
    doSomething();
    flag = false;
    goToSleep();
    powerSensor();
void setFlag ()
  flag = true;
void goToSleep ()
  set_sleep_mode(SLEEP_MODE_PWR_DOWN);
  sleep_enable();
  attachInterrupt(0, setFlag, LOW); // pin D2
  sleep_mode(); //sleep now
  //now sleep until LOW interrupt
  sleep_disable();
  detachInterrupt(0);
void powerSensor ()
  DateTime now = rtc.now(); //get the current date-time
  if ((horaInicio <= now.hour()) && (now.hour() <= horaFin))
    //power on
    digitalWrite (powerPin, HIGH);
    //power off
    digitalWrite (powerPin, LOW);
void doSomething()
  Serial.print(now.year(), DEC);
  Serial.print('/');
  Serial.print(now.month(), DEC);
  Serial.print('/');
  Serial.print(now.date(), DEC);
  Serial.print(' ');
  Serial.print(now.hour(), DEC);
  Serial.print(':');
  Serial.print(now.minute(), DEC);
  Serial.print(':');
  Serial.print(now.second(), DEC);
  Serial.print(' ');
  Serial.print(weekDay[now.dayOfWeek()]);
  sensorValue = analogRead(analogInPin);
    // change the analog out value:
   float voltage = sensorValue * (5.0 / 1023.0);
  // print out the value you read:
  Serial.println(voltage);
  delay (50);
  // wait 5 milliseconds before the next loop
  delay(50);
 // break down 10-bit reading into two bytes and place in payload
  payload[0] = sensorValue >> 8 & 0xff;
  payload[1] = sensorValue & 0xff;
  xbee.send(zbTx);
  // flash TX indicator
  flashLed(statusLed, 1, 10);
  // after sending a tx request, we expect a status response
  // wait up to half second for the status response
  if (xbee.readPacket(500))
    // got a response!
    // should be a znet tx status
    if (xbee.getResponse().getApiId() == ZB_TX_STATUS_RESPONSE) {
      xbee.getResponse().getZBTxStatusResponse(txStatus);
      // get the delivery status, the fifth byte
      if (txStatus.getDeliveryStatus() == SUCCESS) {
        // success.  time to celebrate
        flashLed(statusLed, 5, 50);
        // the remote XBee did not receive our packet. is it powered on?
        flashLed(errorLed, 3, 50);
    // local XBee did not provide a timely TX Status Response -- should not happen
    flashLed(errorLed, 2, 50);
sketch_sensor7.1.ino (4.19 KB)
Series2_Rx_1.1.ino (2.63 KB)
WTF? You are not sending a pin number.
