I have an Arduino Uno connected to a Xbee S2 (router in API mode 2) and it is communicating with a coordinator connected to Raspberry Pi (coordinator in API mode 2). I am able to send and receive packets. I'm working on a wireless sensor network where some sensors are connected to arduino uno and transmit the values through the router (xbee). I'm using Andrew Rapp's arduino-xbee library and on the Pi I am using python-xbee library . But now I want my code to handle a situation where when the connection is broken, the sensor values are stored in a buffer and upon re-establishment of the connection, data from the buffer is sent. I want to do this in Arduino. One chunk of my data looks like this:
uint8_t payload[18] = {'T', 'C', 0, 0, 0, 0, 'H','X', 0, 0, 0, 0, 'L', 'X', 0, 0, 0, 0};
The zeros are replaced with sensor values (I've done that already). I just need a way/code to store each chunk of data in a buffer. I'm not sure how to do this. I check the connection loss by checking the acknowledgement packet (Zigbee transmit status frame). With Andrew's libray it is checked as:
if (xbee.readPacket(500))
// got a response!
// should be a znet tx status
if (xbee.getResponse().getApiId() == ZB_TX_STATUS_RESPONSE)
xbee.getResponse().getZBTxStatusResponse(txStatus);
// get the delivery status, the fifth byte
if (txStatus.getDeliveryStatus() == SUCCESS)
// success. time to celebrate
flashLed(statusLed, 5, 50);
// the remote XBee did not receive our packet. is it powered on?
flashLed(errorLed, 3, 500);
else if (xbee.getResponse().isError())
//Serial.print("Error reading packet. Error code: ");
//Serial.println(xbee.getResponse().getErrorCode());
// local XBee did not provide a timely TX Status Response -- should not happen
flashLed(errorLed, 1, 50);
I just need some help (a short sample code) on how to accomplish storing data in a buffer and then sending it. Thank you ![]()
The complete code file is attached with this post.
ZB_TX.ino (3.11 KB)
