i can send the two values but when i receive them on the other arduino their combined into one number i need to be able to split them into two variables again.
Only if you combined them. Or didn't send them right. Maybe you need to post all of your sender code and all of the receiver code. Any sample output that you get from the sender and/or receiver would be good to see, too.
I think you need to wait for the bytes to arrive...
while (!Serial.available()) {}
incomingByte = Serial.read();
if (incomingByte == 255){
x = Serial.read();
if (incomingByte == 254){
y = Serial.read();
On the receiver, you want to read 4 bytes. So, do nothing unless there are 4 bytes to read:
byte a, x, y;
if(Serial.available() >= 4)
x = 0;
y = 0;
// Read first 2 bytes
a = Serial.read();
if(a == 255) // Next byte goes in x
x = Serial.read();
else if(a == 254) // Next byte goes in y
y = Serial.read();
else // Next byte gets ignored
a = Serial.read();
// Read next 2 bytes
a = Serial.read();
x = Serial.read();
y = Serial.read();
a = Serial.read();
I think, though, that you’d be better off having the sender send the data as text:
<x=189,y=45>
Then, you know where a packet starts (<), where it ends (>), and where the values in the packet start (after the =) and end (at the , or >). Any packet that does not contain a <, a >, a comma, and 2 equal signs is incomplete, and should be discarded.
By the way, you never told us what the problem is with this code. Does it work, or not? If not, what indication do you have that it isn’t working? If it works, what’s the problem?
