I'm quite new to Arduino (a few months) and start really having fun with projects !
For a game I'm building I need to create a fake bomb that players will need to defuse.
That part is almost done.
The hard part is that I would like from my computer to control the timing and control the smoke machine I have in the backroom.
Here is where I'm lost :
1/ I have an Arduino mega with the Xbee Shield
2/ And I have another Xbee with an USB adapter
The second one is recognized by XCTU without any problem, this one will be connected to the computer to send information to the other one (the one connected to the Arduino that is my bomb).
The second one (on the Arduino Mega) is not recognized at all by XCTU.
If I understood well, I need to connect them both to XCTU and pair them.
I tried to switch the jumpers, expand the range of settings in XCTU, I don't know what I did not tried and am a bit lost.
After I will have them connected, I may need more help for configuration, but that's a second part of the project.
You will need to remove the ATMega chip from the Arduino first. Not an easy task, if you want to re-use the chip, which won't be easy, either.
It would be far simpler to use the adapter to program one XBee at a time.
You did not. The XBees need to be configured so that then can connect. But that does not mean "at the same time". Configure one, then configure the other one.
To build my fake bomb, will you advice to start with that part or to stay focused on Xbee connexion ?
I thin both are associate, one is Coordinator API (the one on the Arduino Mega) and the other one is Router/End Device API.
My goal is to be able to launch the bomb timer (first need), to see how much is left (a simple Read) and to activate a digital pin (like a virtual switch, to activate an external switch).
