xbee simple program code for view processing graph
hi. hello everyone here. i'm newbie in both arduino & xbee. i'm currently searching for information about connection for arduino uno board to xbee module & sample program for transmiting analog signal from arduino uno board to receiving xbee to produce a graph view by processing software. basically for analog read from analog input & view a graph by processing software i'm already done. just about the xbee program only i stuck here. it would be glad & my pleasure if u guys can help me. with all, regards. thank you.
What have you tried?
actually i was working with my wireless ecg project…i have done the programming for analog input from the arduino and i have done the programming on how to view the ecg graph using Processing software at the pc…but for now, i’m stuck at the xbee wireless module program because i dont know how to write a program from the arduino through xbee into my pc…i am using arduino uno…i got the program from the internet for xbee but i dont know how to read the program… this is the sample program i found… but, basically i don’t know how to read the program. bcoz i don’t have basic programming. hope u can help me. thank you.
 * Copyright (c) 2009 Andrew Rapp. All rights reserved.
 * This file is part of XBee-Arduino.
 * XBee-Arduino is free software: you can redistribute it and/or modify
 * it under the terms of the GNU General Public License as published by
 * the Free Software Foundation, either version 3 of the License, or
 * (at your option) any later version.
 * XBee-Arduino is distributed in the hope that it will be useful,
 * but WITHOUT ANY WARRANTY; without even the implied warranty of
 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 * GNU General Public License for more details.
 * You should have received a copy of the GNU General Public License
 * along with XBee-Arduino.  If not, see <http://www.gnu.org/licenses/>.
#include <XBee.h>
This example is for Series 1 XBee
Sends a TX16 or TX64 request with the value of analogRead(pin5) and checks the status response for success
Note: In my testing it took about 15 seconds for the XBee to start reporting success, so I've added a startup delay
XBee xbee = XBee();
unsigned long start = millis();
// allocate two bytes for to hold a 10-bit analog reading
uint8_t payload[] = { 0, 0 };
// with Series 1 you can use either 16-bit or 64-bit addressing
// 16-bit addressing: Enter address of remote XBee, typically the coordinator
Tx16Request tx = Tx16Request(0x1874, payload, sizeof(payload));
// 64-bit addressing: This is the SH + SL address of remote XBee
//XBeeAddress64 addr64 = XBeeAddress64(0x0013a200, 0x4008b490);
// unless you have MY on the receiving radio set to FFFF, this will be received as a RX16 packet
//Tx64Request tx = Tx64Request(addr64, payload, sizeof(payload));
TxStatusResponse txStatus = TxStatusResponse();
int pin5 = 0;
int statusLed = 11;
int errorLed = 12;
void flashLed(int pin, int times, int wait) {
    for (int i = 0; i < times; i++) {
      digitalWrite(pin, HIGH);
      delay(wait);
      digitalWrite(pin, LOW);
      if (i + 1 < times) {
        delay(wait);
  pinMode(statusLed, OUTPUT);
  pinMode(errorLed, OUTPUT);
  xbee.setSerial(Serial);
   // start transmitting after a startup delay.  Note: this will rollover to 0 eventually so not best way to handle
    if (millis() - start > 15000) {
      // break down 10-bit reading into two bytes and place in payload
      pin5 = analogRead(5);
      payload[0] = pin5 >> 8 & 0xff;
      payload[1] = pin5 & 0xff;
      xbee.send(tx);
      // flash TX indicator
      flashLed(statusLed, 1, 100);
    // after sending a tx request, we expect a status response
    // wait up to 5 seconds for the status response
    if (xbee.readPacket(5000)) {
        // got a response!
        // should be a znet tx status
    	if (xbee.getResponse().getApiId() == TX_STATUS_RESPONSE) {
    	   xbee.getResponse().getZBTxStatusResponse(txStatus);
    	   // get the delivery status, the fifth byte
           if (txStatus.getStatus() == SUCCESS) {
            	// success.  time to celebrate
             	flashLed(statusLed, 5, 50);
            	// the remote XBee did not receive our packet. is it powered on?
             	flashLed(errorLed, 3, 500);
    } else if (xbee.getResponse().isError()) {
      //nss.print("Error reading packet.  Error code: ");
      //nss.println(xbee.getResponse().getErrorCode());
      // or flash error led
      // local XBee did not provide a timely TX Status Response.  Radio is not configured properly or connected
      flashLed(errorLed, 2, 50);
hai if you have a full functioning Xbee module with a serial port, you can transfer data as using Serial.print(); function. for eg.if you have a analog value get from your ecg , as int x=analogRead(pin);///which analog pin you used Serial.print(x);
Binukannur08: hai if you have a full functioning Xbee module with a serial port, you can transfer data as using Serial.print(); function. for eg.if you have a analog value get from your ecg , as int x=analogRead(pin);///which analog pin you used Serial.print(x);
just serial print function only? just like that? like the program to view the serial monitor? is that so... i try first. i guess juz need to configure the X-CTU only...
hai, What type of BT you are using? if you want more serial you must set up a additional softwareserial. I think you want two one for processing and other for BT.
i am using xbee as my wireless module..i'm working on programming on how to transmit ecg graph from my arduino to pc via my wireless xbee..
The XBees, when properly configured, replace a wire. There is NOTHING that changes in the programming from when you used a wire to connect the Arduino to the PC.
What, exactly, is an ecg graph?
owh…so i just configure the xbees…and then just matching it from transmitter and receiver?..do i need to program it in arduino for xbees?
*ecg graph is ELECTROCARDIOGRAPHY which measure our electrical activity of heart…
How is this graph stored/represented on the Arduino? What, exactly, are you sending?
Which XBees are you using? Have you get them talking to each other?
How are they connected to the Arduino/PC?
