XBee sleep mode in API mode
hello
i'm currently working on a project in which I use antennas such as XBee 2 Wire Antenna - Series 2 (ZigBee Mesh).
the end device have to sleep all the night
How can I configure my antenna to go sleep mode using software in API mode (without using XCTU)?
How am I supposed to wake up the antenna?
It's not the antenna that needs to sleep. It's the microcontroller on the XBee module.
Why are you opposed to using X-CTU?
You really need to work this out BEFORE you go to sleep.
Under what circumstances should the XBee wake up?
it should wake up at 8 am and go to sleep at 6 pm
How will it know what time it is?
If you have an RTC attached that can generate an interrupt at 8 AM, that could wake the XBee up.
