XBee sleeping but not waking up?
Hello I am using the below code to sleep XBee from Arduino. I connect a wire from digital pin of arduino to pin number 9 of XBee. I also configure XBee from XCTU to make it sleep mode.
The below code sleep the Arduino but not waking up? Anything more to do to wake XBee up
#include <avr/sleep.h>
#define XBEE_sleepPin 6
void xbeesleep() {
  Serial.println("sleep");
 delay (3000);
  pinMode (XBEE_sleepPin,OUTPUT);    // put XBee to sleep0
  digitalWrite(XBEE_sleepPin,HIGH);  // Setting this pin to LOW turns off the pull up resistor, thus saving precious current
void xbeewake() {
  Serial.println("wake");
  pinMode(XBEE_sleepPin,OUTPUT);   // Set the "wake-up pin" to output
  digitalWrite(XBEE_sleepPin,LOW); // wake-up XBee
  delay(1000); //make sure that XBee is ready
int i = 0;
  if (i==0)
     xbeewake();
  else if (i==5)
    xbeesleep();
  if (i<5)
  Serial.println(i);
  i = (i+1) % 10;
  delay(3000);
Why isn't the pinMode() done in setup()?
How do you know that the XBee isn't waking up? You don't have the XBee doing anything that I can see, so how do you know that it goes to sleep or wakes up or doesn't?
I tried your code and it seemed to do what it was designed to do. I got:
wake
0
1
2
3
4
sleep
wake
0
1
2
3
4
sleep
wake
0
1
2
3
4
sleep
And pin 6 went on and off.
So what is wrong exactly?
Its working now. I didn't set D7=0; After setting that its sleeping and waking.
