Hi there, i'm posting here because i'm running out of ideas and i'm stuck:
I've been programming a little robot in order to use some programs I wrote, based on two xbee communicating and controlling things.
Now i wanted to turn it into the real world and embbed everything on the robot:
I've got a 9Volt battery powering an arduino MINI on +9V
my embedded xbee transceiver is powered by the same battery, on which i plug a little adjustable voltage divider.
I configure the divider to provide +3V because xbees need 2,8 - 3,3 .
when i plug the xbee in, it is not detected. The arduino still works fine.
I measure a drop of voltage between Vcc and GND of the XBEE ( he now has 1,8v and any of my potentiometer do not allow me to get higher )
have you ever heard of anything like that? What advice could you give me.
NB: my xbees work fine, i still can program them, when i use two breakout boards, the two xbees still communicates, so i'm sure it has NOT burned.
The best choice of v.reg depends upon the module being used. The basic XBee draws
low currents, so any TO-92 100mA v.reg will do. The XBee Pros draw in the range of
250 mA, so you need a much larger current capacity v.reg. I've used both TO-220
LM1117-3.3 and DPAK NCP1117-3.3 devices.
And don't forget the level-shifters.
I use NiMH AA-cells in all my robots, and don't much mess with Lipo myself. The little
9V cells will power an Arduino board, but not for very long, and they'll go flat a lot faster
if also powering Xbees. The NiMH AA-cells have 2000-2500 mAh, but 9V batteries only
600 mAh or so.
