Hello, im trying to make a wireless temp sensor which send packets directly to my own server. The thing is im not pretty sure how to configure it. Im thinking about using x ctu software to do it, with it i can configure the network parameters like destination ip and port, SSID and so on however, i don’t know how to send an specific “plot” to my server which contains SSN, identifier (or something like that) and the signal provide by the temperature sensor in volts or Cº.
You can't, using XBees. You CAN send data to the PC, but the PC then needs to get the data to the server. (No, it doesn't matter that the PC and the server are the same machine. There are completely different processes involved.)
Good idea, since that's the only software you can use.
however, i don't know how to send an specific "plot" to my server which contains SSN, identifier (or something like that) and the signal provide by the temperature sensor in volts or Cº.
The XBees replace wires. Use the EXACT same process you'd use if there were wires in place.
I'm using xBee-Wifi module to connect a microcontroller board with i/o directly to my server using http calls with no problems and without any pc. The thing is now i dont want to use micro in this project. So cant i make this project without xbee to pc to cloud?
Well i could use any hyperterminal with AT commands.
