Hi everyone,
I am new on the forum, and apologise if my format for posting is not up to standard.
I am working on a project with two separate Arduino Mega 2560 boards, and am trying to communicate sensor data gathered from one Arduino to the other (let's call them XBee 1 sending to XBee 2).
My sensor data is gathered just fine, and appears to be transmitted properly as well, with XBee 2 sending a successful response to XBee 1 upon transmission. However, XBee 2 seems to not send the data that was received to my Arduino. The Serial.read() command comes up as -1 (no data), and getresponse().isAvailable() comes up as false.
Here is a sample of my receiving code:
void receive(int *temp_value, int *keypad)
xbee.readPacket();
if (xbee.getResponse().isAvailable())
Serial.println("Available");
if (xbee.getResponse().getApiId() == ZB_RX_RESPONSE)
Serial.println("Data Received");
xbee.getResponse().getZBRxResponse(rx);
int tvalue = rx.getData(0) << 8 | rx.getData(1);
int kvalue = rx.getData(2) << 8 | rx.getData(3);
*keypad = kvalue - 48;
*temp_value = tvalue & 0x2fff;
Serial.println("Not Available");
And a sample of my transmission code:
void transmit (int tempvalue, int keyvalue) {
//payload for key press
payload[0] = keyvalue >> 8 & 0xff;
payload[1] = keyvalue & 0xff;
//payload for temperature reading
payload[2] = (tempvalue >> 8 & 0xff) | 0x40;
payload[3] = tempvalue & 0xff;
xbee.send(zbTx);
Serial.println(tempvalue);
if (xbee.readPacket(500))
if (xbee.getResponse().getApiId() == ZB_TX_STATUS_RESPONSE)
xbee.getResponse().getZBTxStatusResponse(txStatus);
Serial.println("Transmission Successful");
} else Serial.println("XBee did not provide a timely TX status response");
If I plug XBee 2 directly into my computer, using XCTU, I am able to read the sent packets without a problem.
I have searched around the forums as well as on other websites, but seem to come up short, though I think that may be due to my lack of google-fu.
Thank you very much for your help! If there is anything that anyone needs from me, I would be happy to provide.
