xbee with softwareSerial problem.
Using the Physical Pixel example to debug hardware/software setup.
Arduino Nano. XBee Series 1, newest firmware update. Pin Hibernate enabled and working.
These sketches work when implemented for hardware serial to/from xbee.
Sending unit:
#include <SoftwareSerial.h>
SoftwareSerial softSerial0(7,6);///RX/TX
softSerial0.begin(2400);
pinMode(7,INPUT);
pinMode(6,OUTPUT);
pinMode(5,OUTPUT);//through level shifter to xbee sleep pin
digitalWrite(5,LOW);//disable pin hibernate
softSerial0.print(‘H’);
softSerial0.print(‘L’);
Receiving unit:
const int ledPin = 13; // the pin that the LED is attached to
int incomingByte; // a variable to read incoming serial data into
// initialize the LED pin as an output:
pinMode(ledPin, OUTPUT);
pinMode(7,INPUT);
pinMode(6,OUTPUT);
if (softSerial0.available() > 0) {
incomingByte = softSerial0.read();
Serial.println(incomingByte);
// if it’s a capital H (ASCII 72), turn on the LED:
if (incomingByte == ‘H’) {
digitalWrite(ledPin, HIGH);
// if it’s an L (ASCII 76) turn off the LED:
if (incomingByte == ‘L’) {
digitalWrite(ledPin, LOW);
delay(250);
Serial monitor output:
252
252
252
252
252
252
252
252
252
252
252
ad infinitum.
Implemented with hardware serial, printing to serial monitor yields
"72
72
72
72
76
76
76
76
72
72
72
72
76
76
76
76
" And the LED flashes properly.
SoftwareSerial on the sending unit and hardware serial on the receiving unit yields:
248
248
248
248
248
128
248
248
248
248
248
for some reason.
Hardware on send and software serial on receive yields:
Help?
Thx…
Sorry, hit Post too soon...
Hardware on send and software serial on receive yields: " 254 254 254 254 254 254 254 254 254 254 254 254 254 254 "
OK Thanks for nothin', I figure it out:)
In the course of troubleshooting I'd lowered the baud rate for softwareSerial to 2400, in case that was a problem. Meanwhile I got everything else right, but the XBee's are still at their default 9600 baud setting. I upped it to 9600 in the code and everything works. Hadn't realized I'd need to configure the XBee's to a matching rate.
Couple of days chasing this around, Sigh...:)
