Hi i am working on a xbee s6B project where i want to send a HTTP request to stressknap.dk/input.php?id=1
I dont need to get anything returned to the arduino.
I tried out a library: GitHub - cjbearman/xbee-wifi-spi-arduino: Arduino library to support Xbee Wifi modules, using SPI communication but i seem to get alot of errors from the compiler and i cant figure out what is wrong.
Right now i am just compiling an example project: "Network_Scan" to test if the library works.
network_scan.ino
* File network_scan.ino
* Synopsis Simple example sketch to demonstrate network scan
* Author Chris Bearman
* Version 2.0
#include <XbeeWifi.h>
// These are the pins that we are using to connect to the Xbee
#define XBEE_RESET 20
#define XBEE_ATN 2
#define XBEE_SELECT SS
#define XBEE_DOUT 23
// XBee object
XbeeWifi xbee;
// Receive and output scan data
void inbound_scan(uint8_t encryption_mode, int rssi, char *ssid)
Serial.print(F("Scan Information, SSID="));
Serial.print(ssid);
Serial.print(F(", RSSI=-"));
Serial.print(rssi, DEC);
Serial.print(F("dB, Security="));
switch(encryption_mode) {
case XBEE_SEC_ENCTYPE_NONE : Serial.println(F("none")); break;
case XBEE_SEC_ENCTYPE_WEP : Serial.println(F("wep")); break;
case XBEE_SEC_ENCTYPE_WPA : Serial.println(F("wpa")); break;
case XBEE_SEC_ENCTYPE_WPA2 : Serial.println(F("wpa2")); break;
default : Serial.println(F("Unknown")); break;
// Keep track of 10 second intervals at which point we'll initiate scans
unsigned long next_scan;
// Setup routine
// Serial at 57600
Serial.begin(57600);
// Initialize the xbee
bool result = xbee.init(XBEE_SELECT, XBEE_ATN, XBEE_RESET, XBEE_DOUT);
if (!result) {
// Something failed
Serial.println(F("XBee Init Failed"));
while (true) { /* Loop forever - game over */}
// Register for incoming scan data
xbee.register_scan_callback(inbound_scan);
Serial.println("XBee found and configured");
next_scan = millis();
// Main run loop
// Initiate a scan every ten seconds
if (millis() >= next_scan) {
if (xbee.initiateScan()) {
Serial.println(F("Scan initiated"));
Serial.println(F("Failed to initiate scan"));
next_scan = millis() + 10000;
// Process the xbee
xbee.process();
Errors
Arduino: 1.6.3 (Windows 8.1), Board: "Arduino Uno"
In file included from C:\Users\Frederik\Documents\Arduino\libraries\XbeeWifi/XbeeWifi.h:61:0,
from network_scan.ino:10:
network_scan.ino: In function 'void inbound_scan(uint8_t, int, char*)':
C:\Users\Frederik\Documents\Arduino\libraries\XbeeWifi/xbee_atmega.h:80:65: error: reinterpret_cast from type 'const char*' to type '__FlashStringHelper*' casts away qualifiers
#define F(str) reinterpret_cast<__FlashStringHelper *>(PSTR(str))
network_scan.ino:24:16: note: in expansion of macro 'F'
network_scan.ino:26:16: note: in expansion of macro 'F'
network_scan.ino:28:16: note: in expansion of macro 'F'
network_scan.ino:30:51: note: in expansion of macro 'F'
network_scan.ino:31:51: note: in expansion of macro 'F'
network_scan.ino:32:51: note: in expansion of macro 'F'
network_scan.ino:33:51: note: in expansion of macro 'F'
network_scan.ino:34:51: note: in expansion of macro 'F'
network_scan.ino: In function 'void setup()':
network_scan.ino:52:20: note: in expansion of macro 'F'
network_scan.ino: In function 'void loop()':
network_scan.ino:71:22: note: in expansion of macro 'F'
network_scan.ino:73:22: note: in expansion of macro 'F'
Error compiling.
enabled in File > Preferences.
