Xbox 360 wireless controller programming issue
Hi
im having a bit of a issue with the digital write functions for the usb host shield which is connected to a wireless Xbox 360 controller. so far my code works perfectly however i am told that i needed to add something else, which will need me to output two low digital signals. the problem that i am facing is that one of the two signals that i need to output is already defined.
#include <XBOXRECV.h>
USB Usb;
XBOXRECV Xbox(&Usb);
int Second_LeftPin = 8;
int Second_RightPin = 7;
int First_LeftPin = 6;
int First_RightPin = 5;
int lasuPin = 4;
int lasdPin = 3;
int raslPin = 2;
int rasrPin = 14;
int dprPin = 15;
int dplPin = 16;
int crossPin = 17;
int circlePin = 18;
int hwb = 19;
void setup(){
  pinMode(Second_LeftPin, OUTPUT);
  pinMode(Second_RightPin, OUTPUT);
  pinMode(First_LeftPin, OUTPUT);
  pinMode(First_RightPin, OUTPUT);
  pinMode(lasuPin, OUTPUT);
  pinMode(lasdPin, OUTPUT);
  pinMode(raslPin, OUTPUT);
  pinMode(rasrPin, OUTPUT);
  pinMode(dprPin, OUTPUT);
  pinMode(dplPin, OUTPUT);
  pinMode(crossPin, OUTPUT);
  pinMode(circlePin, OUTPUT);
  pinMode(hwb, OUTPUT);
  while (!Serial); // Wait for serial port to connect - used on Leonardo, Teensy and other boards with built-in USB CDC serial connection
  if (Usb.Init() == -1) {
    Serial.print(F("\r\nOSC did not start"));
    while (1); //halt
  Serial.print(F("\r\nXbox Wireless Receiver Library Started"));
  Usb.Task();
    for (uint8_t i = 0; i < 4; i++) {
       if (Xbox.XboxReceiverConnected && Xbox.Xbox360Connected[0]){
/////////////////////////////////////////LT//////////////////
digitalWrite(Second_LeftPin, Xbox.getButtonPress(L2) ? LOW : HIGH);
/////////////////////////////////////////RT/////////////////
digitalWrite(Second_RightPin, Xbox.getButtonPress(R2) ? LOW : HIGH);
/////////////////////////////////////// LB/////////////////
digitalWrite(First_LeftPin, Xbox.getButtonPress(L1) ? LOW : HIGH);
///////////////////////////////////////RB///////////////////////
digitalWrite(First_RightPin, Xbox.getButtonPress(R1) ? LOW : HIGH);
/////////////////////////////////////Left Analog Up/////////////
digitalWrite(lasuPin, Xbox.getAnalogHat(LeftHatY) == 32767 ? LOW : HIGH);
//////////////////////////////////////Left Analog Down//////////
digitalWrite(lasdPin, Xbox.getAnalogHat(LeftHatY) == -32768 ? LOW : HIGH);
///////////////////////////////////////Right Analog left///////
digitalWrite(raslPin, Xbox.getAnalogHat(RightHatX) == -32768 ? LOW : HIGH);
//////////////////////////////////////Right Analog Right///////
digitalWrite(rasrPin, Xbox.getAnalogHat(RightHatX) == 32767 ? LOW : HIGH);
/////////////////////////////////////D Pad Right//////////////
digitalWrite(dprPin, Xbox.getButtonPress(RIGHT) ? LOW : HIGH);
///////////////////////////////////D Pad Left//////////////////
digitalWrite(dplPin, Xbox.getButtonPress(LEFT) ? LOW : HIGH);
///////////////////////////////////D Pad UP//////////////////
///////////////////////////////////D Pad DOWN//////////////////
///////////////////////////////////A Button///////////////////
digitalWrite(crossPin, Xbox.getButtonPress(A) ? LOW : HIGH);
//////////////////////////////////B Button///////////////////
digitalWrite(circlePin, Xbox.getButtonPress(B) ? LOW : HIGH);
//////////////////////////////////Y Button///////////////////
digitalWrite(hwb, Xbox.getButtonPress(Y) ? LOW : HIGH);
       }else{
    digitalWrite(Second_LeftPin, LOW);
    digitalWrite(Second_RightPin, LOW);
    digitalWrite(First_LeftPin, LOW);
    digitalWrite(First_RightPin, LOW);
    digitalWrite(lasuPin, LOW);
    digitalWrite(lasdPin, LOW);
    digitalWrite(raslPin, LOW);
    digitalWrite(rasrPin, LOW);
    digitalWrite(dprPin, LOW);
    digitalWrite(dplPin, LOW);
    digitalWrite(crossPin, LOW);
    digitalWrite(circlePin, LOW);
    digitalWrite(hwb, LOW);
as you can see from my above code what im trying to do is, that once y is clicked both circlePin pin and hwb pin should equal LOW. right now both of them work separately but i need them to turn off at the same time (Y clicked), however i still need the circlePin to work separately away from the Y function
im sorry if this isnt making much sense im trying to phrase it the best i can
thank you
Maybe I misread it, but this seems like a no-brainer.
Use a simple IF statement to see if the Y button is pressed and if so, digitalWrite(circlePin, LOW); digitalWrite(hwb, LOW);
HazardsMind:
i have tried that but it hasn’t worked when i click Y both go off which is good but then B stops working again im so stumped here is the code with the if statement
#ifdef dobogusinclude
#include <spi4teensy3.h>
#endif
USB Usb;
int circlePin = 18;
int hwb = 19;
void setup(){
    while (1); //halt
  Usb.Task();
       if (Xbox.XboxReceiverConnected && Xbox.Xbox360Connected[i]){
     if (Xbox.getButtonPress(B, i)){
     if (Xbox.getButtonPress(Y, i)){
  else{
            digitalWrite(circlePin, HIGH);
            digitalWrite(hwb, HIGH);
im not sure if it is a issue with the loop but if anyone can help me that would be great
thank you
are you using a blue tooth module to recieve the signal?
