Hello,
I still do not own the board, but my intention is
writing/reading Arduino data from a C++ (Carbon) program written
in XCode on MAC OS X (Intel).
I suppose I need to use the serial communication, even if it's plugged into the USB.
Any suggestions, source code snippets?
Thanks
P.S.
Also, I have a more general doubt.... Once I dowloaded the program,
does the board loose it at power off?
Or does it remain written in its permanent memory?
Do you have any code snippets for a PC, Id like to write some C++ (using Dev-C++) but am not sure which library to use. There are so many webpages showing different methods of serial communication that I am a bit confused. Many of the programs that I have found are a bit too complex for my level of programming. Right now I am considering using Python since it appears to be the simplest way to send/recieve data to the serial port.
you could check openFrameworks (about | openFrameworks). It's a nice collection of C++ libraries packaged together. The Xcode setup requires some steps to get it working, but it's well worth it. There is a serial class and it's quite easy to interface oF with Arduino:
Thanks for the tips, that open framework site looks great, will have to test later this afternoon. Ive been experimenting with Python too, its a pretty cool language, was able to send bytes to my arduino using only 3 lines of code!
