XCTU, Arduino 1, Xbee Shield v3.0, Explorer issues
I create this new topic following the dead thread:
The issue is:
I am using two XBee S1 modules. One is connected to the computer USB port through the Explorer breadboard. I can find it with the XCTU software, and send data (because the LED on the board flashes a bit when I send something)
The other is plugged into an XBee v3.0 shield (the one that has an USB/XBEE switch). That one is plugged into an Arduino UNO and finally to the same PC as before through USB.
I can't make them chat.
The only I've managed to do is make this code work:
if (Serial.available())
Serial.write(Serial.read());
So when I write something in the XCTU, it is shown in the Arduino serial explorer, and echoed back to the XCTU console.
It would look like this:
XCTU console:
HelloHello
Arduino serial explorer:
Hello
Writing and sending in the Arduino console makes no effect.
I am also trying to use the Softwareserial header, but that doesn't work at all. Maybe because of the shield?
Ok, I have no clue what to try next. Hopefully this issue has been solved before (though couldn't find the solution in the forum).
Cheers,
Zelite
Post a link to the shield, not a bunch of meaningless mumbo-jumbo.
You have not said ANYTHING about how the the XBees are configured. digi is full of s**t when they say that no configuration is needed.
Might be useful to you, check out one of my post which explains the communication between Arduino and Raspberry pi using Arduino.
