XIAO ESP32-C3 will not run example sketches
I am trying to get some basic control over a XIAO ESP32-C3. I uploaded the board data to my IDE and everything seems to be recognized. I tried to run a basic example sketch for the ESP32 and I get the following results. The error codes seem to be consistent across the sketches I have tried to upload so I believe I have still not gotten all of my settings secured.
I compile and upload the code, but it doesn't quite happen. I do not understand the last line "Hand resetting via reset pin." Can anyone please direct me to that which I am totally missing here>
[code]
 Repeat timer example
 This example shows how to use hardware timer in ESP32. The timer calls onTimer
 function every second. The timer can be stopped with button attached to PIN 0
 (IO0).
 This example code is in the public domain.
// Stop button is attached to PIN 0 (IO0)
#define BTN_STOP_ALARM    0
hw_timer_t * timer = NULL;
volatile SemaphoreHandle_t timerSemaphore;
portMUX_TYPE timerMux = portMUX_INITIALIZER_UNLOCKED;
volatile uint32_t isrCounter = 0;
volatile uint32_t lastIsrAt = 0;
void ARDUINO_ISR_ATTR onTimer(){
  // Increment the counter and set the time of ISR
  portENTER_CRITICAL_ISR(&timerMux);
  isrCounter++;
  lastIsrAt = millis();
  portEXIT_CRITICAL_ISR(&timerMux);
  // Give a semaphore that we can check in the loop
  xSemaphoreGiveFromISR(timerSemaphore, NULL);
  // It is safe to use digitalRead/Write here if you want to toggle an output
  // Set BTN_STOP_ALARM to input mode
  pinMode(BTN_STOP_ALARM, INPUT);
  // Create semaphore to inform us when the timer has fired
  timerSemaphore = xSemaphoreCreateBinary();
  // Use 1st timer of 4 (counted from zero).
  // Set 80 divider for prescaler (see ESP32 Technical Reference Manual for more
  // info).
  timer = timerBegin(0, 80, true);
  // Attach onTimer function to our timer.
  timerAttachInterrupt(timer, &onTimer, true);
  // Set alarm to call onTimer function every second (value in microseconds).
  // Repeat the alarm (third parameter)
  timerAlarmWrite(timer, 1000000, true);
  // Start an alarm
  timerAlarmEnable(timer);
  // If Timer has fired
  if (xSemaphoreTake(timerSemaphore, 0) == pdTRUE){
    uint32_t isrCount = 0, isrTime = 0;
    // Read the interrupt count and time
    portENTER_CRITICAL(&timerMux);
    isrCount = isrCounter;
    isrTime = lastIsrAt;
    portEXIT_CRITICAL(&timerMux);
    // Print it
    Serial.print("onTimer no. ");
    Serial.print(isrCount);
    Serial.print(" at ");
    Serial.print(isrTime);
    Serial.println(" ms");
  // If button is pressed
  if (digitalRead(BTN_STOP_ALARM) == LOW) {
    // If timer is still running
    if (timer) {
      // Stop and free timer
      timerEnd(timer);
      timer = NULL;
[/code]
Following are the error messages:
Sketch uses 240986 bytes (18%) of program storage space. Maximum is 1310720 bytes.
Global variables use 13684 bytes (4%) of dynamic memory, leaving 313996 bytes for local variables. Maximum is 327680 bytes.
esptool.py v4.5.1
Serial port COM4
Connecting...
Chip is ESP32-C3 (revision v0.4)
Features: WiFi, BLE
Crystal is 40MHz
MAC: 34:85:18:07:c8:3c
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 921600
Changed.
Configuring flash size...
Erasing flash (this may take a while)...
Chip erase completed successfully in 17.6s
Compressed 13200 bytes to 9522...
Writing at 0x00000000... (100 %)
Wrote 13200 bytes (9522 compressed) at 0x00000000 in 0.2 seconds (effective 486.9 kbit/s)...
Hash of data verified.
Compressed 3072 bytes to 146...
Writing at 0x00008000... (100 %)
Wrote 3072 bytes (146 compressed) at 0x00008000 in 0.0 seconds (effective 495.8 kbit/s)...
Compressed 8192 bytes to 47...
Writing at 0x0000e000... (100 %)
Wrote 8192 bytes (47 compressed) at 0x0000e000 in 0.1 seconds (effective 755.2 kbit/s)...
Compressed 252272 bytes to 139867...
Writing at 0x00010000... (11 %)
Writing at 0x0001b098... (22 %)
Writing at 0x0002312a... (33 %)
Writing at 0x00029331... (44 %)
Writing at 0x0002f539... (55 %)
Writing at 0x000354e7... (66 %)
Writing at 0x0003d306... (77 %)
Writing at 0x00043eec... (88 %)
Writing at 0x0004a082... (100 %)
Wrote 252272 bytes (139867 compressed) at 0x00010000 in 2.3 seconds (effective 895.4 kbit/s)...
Leaving...
Hard resetting via RTS pin...
What error messages ?
Looks like the program loaded OK ?
Does the program run if you press the reset button ?
Probably easiest to try a simple LED blink ort similar.
Can you tell me what that last line means? The sketch I uploaded isn't the best for demo purposes. I will try a basic blink sketch to see if it works. Thank you, though . . . I thought I was wrong but I might be mistaken.
Not a lot.
If you were using a USB to serial adapter or similar that has has a RTS pin that can be used to reset the Arduino.
youre XIAO ESP32-C3 has 2 bottom , one for Boot and one for Reset.
normaly befor upload codes press Boot & hold , press Reset & hold , ilsen to the Reset Sound form PC , relies Reset , lisen Reset Relies Sound form PC , relies Boot Botton , now upload Code.
for starting the uploadet code in the XIAO ESP32-C3 you have to press short the Reset Bottom .
your Error Screen was showing well the upload procedure .
An XIAO ESP32-C3 has 2 Modi , one for upload the Code , and one for run the code , this is the reason for the bottom prosedure.
