Hi Guys,
I have a problem with the following code. I trying to write HTTP PUT commands to Xively. I aware that they have a Arduino friendly library which I already have used with success however; the library doesn't support Location data by Waypoints so I can't display where my device is on the little google map they have on the dashboard.
I thought I might hack the old Pachube example which comes with the IDE and change the API to suit Xively. From about the is point onwards it starts to head down hill...
#include <Wire.h>
#include <SPI.h>
#include <Ethernet.h>
// MAC address for your Ethernet shield
byte mac[] = {0x90, 0xA2D, 0xDA, 0x0D, 0xFD, 0xFA};
// RTC home register address
const int DS3232_I2C_Address=0x68;
// Your Xively key to let you upload data
const char API_key[] = "0qeB68UHfHYClShV4tuGHHqBMWcN0KrTz1SND7JRpmuDWihP";
const unsigned long feedID = 1951066047;
const char streamCount = 1;
const char serverName[] = "www.xively.com";
// Define the strings for our datastream IDs
char sensorId[] = "Temperature";
EthernetClient client;
Serial.println("Starting single datastream upload to Xively...");
while (Ethernet.begin(mac) != 1)
Serial.println("Error getting IP address via DHCP, trying again...");
delay(15000);
int contLength = outPutJSON(Serial);
if(feed(feedID, contLength) == true)
Serial.println("Feed up-dated");
delay(5000);
Serial.println("Unable to update feed");
delay(5000);
boolean feed(unsigned long ID, int length)
boolean result=false;
if(client.connect(serverName, 80) > 0)
client.print("PUT /v2/feeds/");
client.print(feedID);
client.println(".json HTTP/1.0");
client.print("Content-Length: ");
client.println(length+2, DEC);
client.println("Host: api.xively.com");
client.print("X-ApiKey: ");
client.println(API_key);
client.print("Connection: close");
client.println();
outPutJSON(client);
client.println();
// if you couldn't make a connection:
Serial.println("Connection failed");
if(client.connected())
Serial.println("Connected");
if(client.find("HTTP/1.0") && client.find("200") == true)
Serial.println("200 OK");
result=true;
else if(client.find("HTTP/1.0") && client.find("400") == true)
Serial.println("400 Bad Request");
else if(client.find("HTTP/1.0") && client.find("401") == true)
Serial.println("401 Not Authorized");
else if(client.find("HTTP/1.0") && client.find("403") == true)
Serial.println("403 Forbidden");
else if(client.find("HTTP/1.0") && client.find("404") == true)
Serial.println("404 Not Found");
else if(client.find("HTTP/1.0") && client.find("406") == true)
Serial.println("406 Not Acceptable");
else if(client.find("HTTP/1.0") && client.find("422") == true)
Serial.println("422 Unprocessable Entity");
else if(client.find("HTTP/1.0") && client.find("500") == true)
Serial.println("500 Internal Server Error");
else if(client.find("HTTP/1.0") && client.find("503") == true)
Serial.println("503 No server error");
Serial.println("I dont know what is happening?");
Serial.println("Disconnected");
client.stop();
client.flush();
return result;
int outPutJSON(Stream &stream)
float temperature=getTemperature();
int count=0;
count+=stream.println("{");
count+=stream.println("\"version\":\"1.0.0\",");
count+=stream.println("\"datastreams\" : [ {");
count+=stream.println("\"id\" : \"Temperature\",");
count+=stream.print("\"current_value\" : \"");
count+=stream.print(temperature,2);
count+=stream.println("\"");
count+=stream.println("}");
count+=stream.println("]");
return count;
float getTemperature()
byte MSB, LSB;
float degreesC;
// retrieve data from DS3232
Wire.beginTransmission(DS3232_I2C_Address);
Wire.write(0x11); // set DS3232 register pointer to 00h
Wire.endTransmission();
Wire.requestFrom(DS3232_I2C_Address, 8); // request 7 bytes of data from DS3232 starting from register 00h
MSB=Wire.read();
LSB=Wire.read()>>6;
// send it to the serial monitor
degreesC = MSB+0.25*LSB;
return degreesC;
I can't even get a HTTP response from the request :0 Are any of you guys know what I'm doing wrong?
regards
Adam
