I have a uno which has the omniboot loader installed. If I use the Arduino IDE and program it, it loads fine and the verbose output says avrdude is loading MyFoo.ino.hex. If I use Xloader to load the same file, it works fine also. But if I use Xloader to load MyFoo.ino.with_bootloader.hex it loads OK, the program starts to run, then Xloader say "Upload Failed".
I got both the hex files from the Local Temp directory produced by Arduino.
I want to be able to update the original version of MyFoo using Xloader repeatedly as new versions of MyFoo come out. That is why I thought I needed to use the "with_bootloader" version of the hex file. But now I am thinking that it is trying to install the bootloader twice or something. MyFoo is pretty large, so putting it in twice might not fit.
I am really guessing at what is going on here. I hope someone can set me straight. Which hex file should I be using?
