XPL Need help
Hi!
Relly need help on this.
I whant to send data that i recived using X10 to Xpl. Downloaded the lib and tested the example:
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
#include "xPL.h"
xPL xpl;
unsigned long timer = 0;
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(10, 0, 0, 177);
IPAddress broadcast(10, 0, 0, 255);
EthernetUDP Udp;
void SendUdPMessage(char *buffer)
    Udp.beginPacket(broadcast, xpl.udp_port);
    Udp.write(buffer);
    Udp.endPacket();
  Ethernet.begin(mac,ip);
  Udp.begin(xpl.udp_port);
  xpl.SendExternal = &SendUdPMessage;  // pointer to the send callback
  xpl.SetSource_P(PSTR("xpl"), PSTR("arduino"), PSTR("test")); // parameters for hearbeat message
  xpl.Process();  // heartbeat management
   // Example of sending an xPL Message every 10 second
   if ((millis()-timer) >= 10000)
     xPL_Message msg;
     msg.hop = 1;
     msg.type = XPL_TRIG;
     msg.SetTarget_P(PSTR("*"));
     msg.SetSchema_P(PSTR("sensor"), PSTR("basic"));
     msg.AddCommand_P(PSTR("device"),PSTR("1"));
     msg.AddCommand_P(PSTR("type"),PSTR("[b]temp[/b]"));
     msg.AddCommand_P(PSTR("current"),PSTR("22"));
     xpl.SendMessage(&msg);
     timer = millis();
But then i try to replace “temp” in the example with a variabel i only get
initializer fails to determine size of '__c'
Any tip?
But then i try to replace "temp" in the example with a variabel i only get
But, you don't want to tell us what variable, or how?
Are you replacing "temp" in the PSTR() macro with something other than a string? That's going to fail.
Of course, you can use dtostrf() or itoa() to convert values to strings, and then use them in the PSTR() macro.
Yep… use dtostrfbuffer.
msg.AddCommand(“current”,dtostrfbuffer);
Hi!
Sorry… This is the code that is not working…
/* Arduino Interface to the PSC05 X10 Receiver.                       BroHogan 3/24/09
 * SETUP: X10 PSC05/TW523 RJ11 to Arduino (timing for 60Hz)
 * - RJ11 pin 1 (BLK) -> Pin 2 (Interrupt 0) = Zero Crossing
 * - RJ11 pin 2 (RED) -> GND
 * - RJ11 pin 3 (GRN) -> Pin 4 = Arduino receive
 * - RJ11 pin 4 (YEL) -> Pin 5 = Arduino transmit (via X10 Lib)
 * NOTES:
 * - Must detach interrup when transmitting with X10 Lib
#include <SPI.h>
#include "xPL.h"
#include <x10.h>                       // X10 lib is used for transmitting X10
#include <x10constants.h>              // X10 Lib constants
#define RPT_SEND 2
#define ZCROSS_PIN     2               // BLK pin 1 of PSC05
#define RCVE_PIN       4               // GRN pin 3 of PSC05
#define TRANS_PIN      5               // YEL pin 4 of PSC05
#define LED_PIN        13              // for testing
x10 SX10= x10(ZCROSS_PIN,TRANS_PIN,RCVE_PIN,LED_PIN);// set up a x10 library instance:
xPL xpl;
byte mac[] = { 0x90, 0xA2, 0xDA, 0x0D, 0xF5, 0xE2 };
IPAddress ip(192, 168, 73, 91);
IPAddress broadcast(192, 168, 73, 255);
EthernetUDP Udp;
    Udp.write(buffer);
    Udp.endPacket();
  xpl.SetSource_P(PSTR("xpl"), PSTR("spc4300"), PSTR("alive")); // parameters for hearbeat message
// A simple test program that demonstrates integrated send/receive
// prints X10 input, then sets D5 on/off if unit code on input was 1
void loop(){
  if (SX10.received()) {                         // received a new command
  String hus = "A";
  String kod = "1";
  String commando = "off";
    if (SX10.cmndCode() == ON )
        commando = "on";
        commando = "off";
  kod = String(SX10.unitCode());  // returns integer unit code
  hus = String(SX10.houseCode()); // returns ascii A-P human readable house code
  xPL_Message msg;
     msg.hop = 1;
     msg.SetTarget_P(PSTR("rfxcom-lan.0004a35960c9"));
     msg.SetSchema_P(PSTR("x10"), PSTR("basic"));
     msg.AddCommand_P(PSTR("device"),PSTR(hus+kod));
     msg.AddCommand_P(PSTR("command"),PSTR(commando));
  SX10.reset();
I will check the input from you and see if it will help…
//micke
