'XXX' was not declared in this scope
I've run across a strange error. I suspect it has something to do with how .ino files are processed. Here's my code (in a .ino file):
void g() {}
struct XXX { int x; };
void f(XXX s) {}
void setup() {}
void loop() {}
And here are the errors that occur when it is compiled:
....sketch_aug15a.ino:3:8: error: variable or field 'f' declared void
void f(XXX s) {}
....sketch_aug15a.ino:3:8: error: 'XXX' was not declared in this scope
exit status 1
Compilation error: variable or field 'f' declared void
The error goes away if I delete void g() {}.
It also goes away if I used the struct keyword before XXX s, but that shouldn't be necessary.
It also goes away if I precede the definition of f() with a declaration of f() using the same syntax.
Names can be changed and the error stays, e.g. "f" can be changed to another name.
Any ideas?
I have moved your topic to Programming Questions....More suitable for the issue then Arduino IDE 2.x.
I confirm this also happens with wokwi.
void g() {}
void f(XXX s) {}
void setup() {}
void loop() {}
While this way it compiles without errors.
It's from the Arduino IDE's auto-prototype generator being fooled. You can fix it by moving the struct declaration as shown in the previous post or adding a superfluous prototype for the f() function:
void g() {
struct XXX {
  int x;
void f(XXX s);
void f(XXX s) {
