There are some places where you have used == where you should have used =
Where you assign to a variable you need to use = not ==
Change this:
if(digitalRead(xStopMin) == HIGH){
xIs0 == true;
xPos = 0;
Serial.println("xMin");
else xIs0 == false;
to this:
xIs0 = true;
xPos = 0;
else xIs0 = false;
and similar for the other end stop checks. (the == in the if is correct)
Look at = - Arduino Reference and http://arduino.cc/en/Reference/If for more info on when to use = or ==
I don't think this is the cause of the problem of xPos and yPos always reading 0, but it can't hurt to fix it.
