XY Plotter/CNC style interpolation project. Need great deal of help
stimmer, sirbow, wildbill --- thanks for all your help so far!
I am getting a readout for xpos and ypos, but now that I have fixed the xIs0 == true to xIs0 = true, the switches seem to be seriously misbehaving. I am not sure what's going on, but they seem to constantly read out high.
/* Stepper Motor Controller ;  language: Wiring/Arduino
 This program drives a unipolar or bipolar stepper motor.  by Tom Igoe */
/* significant help from arduino forum superstars: sirbow2, stimmer
#include <Stepper.h>
#define motorSteps 200     // change this depending on the number of steps
#define motor2Steps 200     // change this depending on the number of steps
// per revolution of your motor
#define motorPin1 2
#define motorPin2 3
#define motorPin3 4
#define motorPin4 5
#define motorPin6 8
#define motorPin7 9
#define motorPin8 10
#define motorPin9 11
int reading = 0;
int previous = LOW;
long time = 0;         // the last time the output pin was toggled
long debounce = 50;   // the debounce time, increase if the output flickers
int state = HIGH;
//set pin numbers
int xStopMax = A1;
int xStopMin = A0;
int yStopMin = A3;
int yStopMax = A2;
int xPos;
int yPos;
boolean xIs0;
boolean xIsMax;
boolean yIs0;
boolean yIsMax;
// initialize of the Stepper library:
Stepper yAxis(motorSteps, motorPin1,motorPin2, motorPin3, motorPin4);
Stepper xAxis(motor2Steps, motorPin6,motorPin7, motorPin8, motorPin9);
  // set the motor speed at 60 RPMS:
  xAxis.setSpeed(60); //x
  yAxis.setSpeed(60); //y
  //set limit switches to analog inputs
  pinMode(xStopMin, INPUT);
  pinMode(xStopMax, INPUT);
  pinMode(yStopMin, INPUT);
  pinMode(yStopMax, INPUT);
  xPos = 0;
  yPos = 0;
  // Initialize the Serial port:
  //check limit switches
  if(digitalRead(xStopMin) == HIGH){
    xIs0 = true;
    xPos = 0;
    Serial.println("xMin");
  else xIs0 = false;
  if(digitalRead(xStopMax) == HIGH){
    xIsMax = true;
    Serial.println("xMax");
  else xIsMax = false;
  if(digitalRead(yStopMin) == HIGH){
    yIs0 = true;
    Serial.println("yMin");
    yPos = 0;
  else yIs0 = false;
  if(digitalRead(yStopMax) == HIGH){
    yIsMax = true;
    Serial.println("yMax");
  else yIsMax = false;
  char val=0;
  if(Serial.available()) val = Serial.read();
  //keyboard control
  switch(val){
  case 'N':
    Serial.read();
      moveN(200);
    break;
  case 'S':
    Serial.read();
      moveS(200);
    break;
  case 'E':
    Serial.read();
      moveE(200);
    break;
  case 'W':
    Serial.read();
      moveW(200);
    break;
    //diagonal (moving motors almost at the same time)
  case 'J': //NE
    Serial.read();
          moveNE(200);
    break;
  case 'H': //NW
     Serial.read();
          moveNW(200);
    break;
  case 'X': //SE
    Serial.read();
          moveSE(200);
    break;
  case 'Z': //SW
     Serial.read();
          moveSW(200);
    break;
  case 'C': //SW
     Serial.read();
          moveCirc();
    break;
  //resets
  case 'Q': //reset to 0,0
     Serial.read();
         moveN(100);
         moveE(100);
     break;
 //debugs
   case 'P':
     Serial.read();
       Serial.print("x position: ");
       Serial.println(xPos);
       Serial.println("y position: ");
       Serial.println(yPos);
    break;
  default:
    Serial.read();
    delay(10);
    break;
//movement functions
  //first, str  aight up down left right
void moveE(int numSteps){
    int s = 0;
    while(!digitalRead(xStopMax)&& s<numSteps)//checks the button each step, also checks to see if it has moved s amount of steps
          xAxis.step(1);
          s++;
      delay(100);
     xPos += numSteps;
void moveW(int numSteps){
     int s = 0;
    while(!digitalRead(xStopMin)&& s<numSteps)//checks the button each step, also checks to see if it has moved s amount of steps
          xAxis.step(-1);
          s++;
      delay(100);
    xPos -= numSteps;
void moveN(int numSteps){
   int s = 0;
    while(!digitalRead(yStopMax)&& s<numSteps)//checks the button each step, also checks to see if it has moved s amount of steps
          yAxis.step(-1);
          s++;
      delay(100);
    yPos += numSteps;
void moveS(int numSteps){
  int s = 0;
    while(!digitalRead(yStopMin)&& s<numSteps)//checks the button each step, also checks to see if it has moved s amount of steps
          yAxis.step(1);
          s++;
      delay(100);
    yPos -= numSteps;
//diagonals
void moveNE(int numSteps){
  int s=0;
  while(!digitalRead(xStopMax) && !digitalRead(yStopMin) && s<numSteps);
    for(int s=0; s<numSteps; s++)
        yAxis.step(-1);
        xAxis.step(1);
   xPos += numSteps;
   yPos -= numSteps;
void moveSE(int numSteps){
   int s=0;
  while(!digitalRead(xStopMax) && !digitalRead(yStopMax) && s<numSteps);
        yAxis.step(1);
        xAxis.step(1);
   xPos += numSteps;
   yPos += numSteps;
void moveSW(int numSteps){
  int s=0;
    while(!digitalRead(xStopMin) && !digitalRead(yStopMax) && s<numSteps);
          yAxis.step(1);
          xAxis.step(-1);
   xPos -= numSteps;
   yPos += numSteps;
void moveNW(int numSteps){
  int s=0;
    while(!digitalRead(xStopMin) && !digitalRead(yStopMin) && s<numSteps);
          yAxis.step(-1);
          xAxis.step(-1);
   xPos -= numSteps;
   yPos -= numSteps;
void moveCirc(){
   //draw circle at x,y 50,50
    int CircleXCenter = 2;
    int CircleYCenter = 2;
    int CurXPos = xPos; //where the platform currently is in X
    int CurYPos = yPos; //where the platform currently is in Y
    int Rad = 1;
    for (int i = 0; i < 360; i++)
    //it does this for each point of the circle, so you dont have to run them at the same time
       float
       angle = i*2*3.14/360;
        xPos = CircleXCenter + (cos(angle) * Rad);
        yPos = CircleYCenter + (sin(angle) * Rad);
        if(CurXPos < xPos)
               xAxis.step(xPos - CurXPos);
              //movexnow = Xpos - CurXPos;
           //MoveXNow = CurXPos - Xpos;
        if(CurYPos < yPos)
               yAxis.step(yPos - CurYPos);
             //   MoveYNow = Ypos - CurYPos;
             //MoveYNow = CurYPos - Ypos;
      // step(xAxis);
       //step(yAxis);
                 //<100, so -1
       if(i == (360-1)) //we are at end of for loop, save current position.
           CurYPos = yPos;
           CurXPos = xPos ;
