"Year 2000 problem" in Arduino
The micros( ) in wiring.c function using the the variable timer0_millis, which is defined volatile unsigned long timer0_millis , the maximum value is oxFFFFFFFF . It adds MILLIS_INC on each Timer0 interrupt(at 12MHZ clock, the MILLIS_INC = 1). After (0xFFFFFFFF/MILLIS_INC) Timer0 interupts, timer0_millis will become 0 on next interrupt, so the delay( ) function will occur the “Year 2000 problem” , because it uses if (((uint16_t)micros() - start) >= 1000) ,which the micros() is equal timer0_millis.
At about 68 days, it maybe accur “Year 2000 problem”.
by Rom Huang
All this is well known so:-
So what is your point or question?
rom: At about 68 days, it maybe accur "Year 2000 problem".
I would assume that is why the millis() reference page (http://arduino.cc/en/Reference/Millis) says: "This number will overflow (go back to zero), after approximately 50 days."
The solution is very simple and well documented: http://arduino.cc/playground/Code/TimingRollover
