Yeat Another Finite State Machine, YA_FSM
Hello everybody :sunglasses:
I would like to introduce this library that I just updated to version 1.0.7
The name chosen, YA_FSM, I have to admit that it is a bit unhappy and does not help much to understand what it was born for at first glance.
This is a library that allows to implement a finite state machine operating mainly in a declarative way, in order to shift the programmer's efforts to the design of a good working automaton rather than to the raw implementation of the necessary C++ code.
It was thinked as a way to reproduce a working model developed according to SFC (Sequential Function Chart) - GRAFCET programming styles on a microcontroller like you could do with modern PLCs for example.
For that reason it rely on concepts like:
  • steps - the finite states;
  • transitions - the condition which trig the step change
  • actions - what to do in each step
I've prepared a wokwi project for almost every example included in library where some simple and common automations are implemented (with different approaches):
I hope this work can be useful for someone and obviously if you have constructive suggestions for improvement or additional features, it will be very welcome.
This looks like a very nice library. Thank you for sharing.
I was wondering whether this is really an implementation of a Petri net though, as these typically have multiple inputs and outputs per node and the state is defined by the distribution of multiple tokens over the nodes. I could not find an example of this, nor could I see any data structure in the source code that implements this at first glance.
By the way, I have some ideas about a (very simple, yet readable) implementation for FSMs that I can share here if you think it will not pollute your thread.
Yes you are right.
Indeed let's say that it is inspired by Petri net, but it does not exactly meet all the formal requirements.
You mean something like this?
With YA_FSM you could translate the model in this way, but for how it works now, parallel steps it's not implemented.
fsm.AddTransition(P0, P1, T0);
fsm.AddTransition(P1, P2, T1);
fsm.AddTransition(P1, P2, T2);
fsm.AddTransition(P2, P3, T3);
this transition will never be evaluated because also the previous is active
at the same time and then causes the return of the Update() method.
fsm.AddTransition(P2, P0, T3);
fsm.AddTransition(P3, P0, T4);
I think we can live with this problem without worries because it 's enought define a new distinct transition T3_a equivalent to T3 to handle the behavior.
Probably this could be also done directly inside the library, it would be a big improvement.
I have to think about to-do it, but in the meantime thanks for the food for thought!
Yes please, pollute the thread!!! :rofl: :rofl: :rofl:
I think as long as you do not want to handle actual concurrency, your implementation is fine as it is.
[edit] In hindsight it is better to do this in a separate thread.
