I suddenly got to work on my Alarm system.
The only then yet i installed is a doormagnet for my door, so when the door opens, the sirene goes on for like 10 secs, and then if the door is closed again, the alarm turns off.
I got 3 leds.
Red for when alarm is on.
Green for when Door is closed and everything is OK.
And a Yellow. And for the yellow i have a little question.
Yellow:
My idea is, when the alarm is on, and the door still i open, the yellow led should just be LOW. But when the door is closed and the sirene is still on (delay(10000) the yellow LED should start to blink with a delay of 100 mil until the sirene is off (as it is after 10 secounds, when the door is closed), then it should be LOW- but i dont know how i can do that - i tryed for hours last day, but notin dident work
Look at my code:
int ledPin = 13; // choose the pin for the LED
int inPin = 2; // choose the input pin (for a pushbutton)
int val = 0; // variable for reading the pin status
int dor = 0;
int alarmPin = 6;
int greenPin = 7;
int yellowPin = 4;
int butPin = 3;
pinMode(ledPin, OUTPUT); // declare LED as output
pinMode(inPin, INPUT); // declare pushbutton as input
pinMode(alarmPin, OUTPUT);
pinMode(greenPin, OUTPUT);
pinMode(yellowPin, OUTPUT);
pinMode(butPin, INPUT);
void loop(){
val = digitalRead(inPin); // read input value
if (val == LOW) { // check if the input is HIGH (button released)
digitalWrite(ledPin, LOW); // turn LED OFF
digitalWrite(alarmPin, LOW);
digitalWrite(greenPin, HIGH);
digitalWrite(yellowPin, LOW);
digitalWrite(alarmPin, HIGH);
digitalWrite(greenPin, LOW);
delay(150);
digitalWrite(ledPin, HIGH); // turn LED ON
delay(10000);
digitalWrite(yellowPin, HIGH);
delay(200);
delay(200);
Can anyone tell me how to do that?.
And then i have another question
- the Arduino board is only 5v - and it wont work if i put in a 9v battery to my solderless breadboard instead of the power from the arduino board. Like the sirene needs atleast 12v (a better one i want for ths project) and some moton detectors needs more power. So how am i supposed to add like 12v power supply to the breadboard?
Thank you all, and MERRY CHRISTMAS!
