Yet an other RGB Project
Ok, first post here.
I want to show you my first arduino project. The aim was, to create something for my room. There was one blank wall over my bed i wanted to fill. i decided to build a LED-Panel.
Took longer than i thought :slight_smile:
here are some Specs:
  • 38 RGB LEDs
  • 3xTLC 5940
  • some wires
  • 110x90cm acrylic glas
  • random colors (fading very smooth from one to the other color)
at first, i dint like the light from the RGB leds. they are clear ones, so you could see the Dots of the different colors. I tried to solve that with some very fine sandpaper, but that wasnt good enough. i fixed the problem with a small piece of tape (the one used to cover switches when painting a room). That affects the brightness, i like the result.
some tasks are left undone:
-the view from the side isnt the nicest, i should apply something.....yeah....something is good :wink:
-the arduino is glued on the panel....so i need a new one. i was to lazy to build a free running board
-the prototype board left on the panel. my lazyness again :wink:
  • some LEDs have are a bit darker than the others....i should change them...
And the code
#include "tlc_config.h"
#include "Tlc5940.h"
int red0;
int blue0;
int green0;
int color=1;
int blue=16;
int red=16;
int green=16;
int green_change;
int red_change;
int blue_change;
int time=0;
  Tlc.init();
  Tlc.clear();
   pinMode(6, OUTPUT);
   pinMode(7, OUTPUT);
   pinMode(8, OUTPUT);
   green_change = random(16);
   blue_change = random(16);
   red_change =random(16);
   green0= green * 250 + time * (green_change-green) / 4 ;
   red0  = red   * 250 + time * (red_change  -red  ) / 4 ;
   blue0 = blue  * 250 + time * (blue_change -blue ) / 4 ;
   time=time+1;
   if (time>1000){
     time=0;
     green=green_change;
     red=red_change;
     blue=blue_change;
  color_set(1);
void color_set(int repeat){
  for (int x=0;x<repeat;x++){
  if (color==1){
     Tlc.setAll(blue0);
     Tlc.update();
     while(tlc_needXLAT);
     color=2;
     digitalWrite(6,0);
     digitalWrite(8,1);
  if (color==2){
     Tlc.setAll(red0);
     Tlc.update();
     color=3;
     digitalWrite(8,0);
     digitalWrite(7,1);
  if (color==3){
     Tlc.setAll(green0);
     Tlc.update();
     color=1;
     digitalWrite(7,0);
     digitalWrite(6,1);
ImageShack - Best place for all of your image hosting and image sharing needs green
ImageShack - Best place for all of your image hosting and image sharing needs side view
ImageShack - Best place for all of your image hosting and image sharing needs rear view
ImageShack - Best place for all of your image hosting and image sharing needs front view
some random colors:
You can make all that, yet you can't make your bed?
i can...but i don't do it :wink:
