Yet another Arduino Data Logger
Hello all,
I’m new to the forum, been learning and building with Arduino for a while and have made some good progress, however, I have recently hit a stumbling block with my data logger project.
I am attempting to log at high frequency (4x per sec) the waggle of a joystick (RS 548-7648; just off the top right of the pic), I have interfaced a DS1307 RTC and a MicroSD transflash break out from Sparkfun (via voltage divider). Several LEDs are currently connected to act as error/notifications. It is a ATMega328.
Hardware seems to work fine, logging well. The issue comes when I leave the device logging for several hours. My green LED still blinks and the free space on the SD Card decreases proportionally, but no file is visible in Windows when I remove it from the logger. I am using the FAT16 Library to log to MicroSD. It works well for minutes to about an hour and then “keeps” running but doesn’t write a visible file. It could be related to the voltage divider/Fat16 issue, but with the logger working well initially, could explain the longer term problem?
I have also tried Filelogger and that didn’t work for longer periods, giving me a corrupt file when I attempt to read the card in Windows.
I am just wondering if it is something that I am obiously over-looking?
Here is my draft code:
// Wave exposure meter version 0.2
//Lets try Fat16
#include <Fat16.h>
#include <Fat16util.h>
// Include files for clock DS1307 library
#include <WProgram.h>
#include <Wire.h>
#include <DS1307.h>
// FAT16Lib Analogger Code: A simple data logger for the Arduino analog pins
#define LOG_INTERVAL 250    // mills between entries
#define SENSOR_COUNT     2 // number of analog pins to log
#define ECHO_TO_SERIAL   0 // echo data to serial port
#define WAIT_TO_START    0 // Wait for serial input in setup()
#define SYNC_INTERVAL 1000  // mills between calls to sync()
uint32_t syncTime = 0;     // time of last sync()
#define error(s) error_P(PSTR(s))
//Init for SD Cards FAT16
SdCard card;
Fat16 file;
// The pins to power LEDs for notifications and error checking
int ledPinY = 5; //yellow
int ledPinG = 6; //green
int ledPinR = 7; //red
// Initialise record count variable
long reccount = 0;
//Setup, code runs once per run
void setup(void)
//led initialse pins as outputs
  pinMode(ledPinG, OUTPUT);
  pinMode(ledPinR, OUTPUT);
  pinMode(ledPinY, OUTPUT);
#if WAIT_TO_START
  Serial.println("Type any character to start");
  while (!Serial.available());
#endif //WAIT_TO_START
// initialize the SD card, using true as I'm using a resistor voltage control for SD Card
  if (!card.init(true))
    digitalWrite(ledPinY, HIGH); //red and yellow on for error
    digitalWrite(ledPinR, HIGH);
    error("card.init");
  if (!Fat16::init(card))
    digitalWrite(ledPinY, HIGH); //all lights on for error
    digitalWrite(ledPinG, HIGH);
    error("Fat16::init");
// Now let's create a new logging file
  char name[] = "LOGGER00.CSV";
  for (uint8_t i = 0; i < 100; i++)
    name[6] = i/10 + '0';
    name[7] = i%10 + '0';
  if (file.open(name, O_CREAT | O_EXCL | O_WRITE))break;
  if (!file.isOpen()) error ("file.create");
  Serial.print("Logging to: ");
  Serial.println(name);
// Write the header at the top of the log file
  file.writeError = 0;
  file.print("time");
  file.print(",");
  file.print("date");
  file.print(",");
  file.print("records");
#if ECHO_TO_SERIAL
  Serial.print("time");
  Serial.print(",");
  Serial.print("date");
  Serial.print(",");
  Serial.print("records");
#endif //ECHO_TO_SERIAL
//Test the number of sensors to log
#if SENSOR_COUNT > 6
#error SENSOR_COUNT too large
#endif //SENSOR_COUNT
//Cycle number of sensors and write header for each
  for (uint8_t i = 0; i < SENSOR_COUNT; i++)
    file.print(",sens");file.print(i, DEC);
    #if ECHO_TO_SERIAL
    Serial.print(",sens");Serial.print(i, DEC);
  file.println();
  #if ECHO_TO_SERIAL
  if (file.writeError || !file.sync())
    error("write header");
    digitalWrite(ledPinG, HIGH); //red and green on for error
//Void Loop, all the main processing is done in here.
void loop(void)
  reccount = reccount + 1;
  // clear print error
  delay((LOG_INTERVAL -1) - (millis() % LOG_INTERVAL));
  //hold time/date values
  char time[8];
  char date[9];
  // lets log it!
  file.print(getClock(time));
  file.print(',');
  file.print(getDate(date));
  file.print(',');
  file.print(reccount);
  #if ECHO_TO_SERIAL
  Serial.print(getClock(time));
  Serial.print(',');
  Serial.print(getDate(date));
  Serial.print(',');
  Serial.print(reccount);
  // log the sensor data
  for (uint8_t ia = 0; ia < SENSOR_COUNT; ia++)
    uint16_t data = analogRead(ia);
    file.print(',');
    file.print(data);
    #if ECHO_TO_SERIAL
    Serial.print(',');
    Serial.print(data);
  file.println();
  #if ECHO_TO_SERIAL
  //blink LED to show logging status
  digitalWrite(ledPinG, (millis() / 500) & 1);
  //Notify upon error
  if (file.writeError)
    error("write data");
  // FAT16Lib OK regulate the amount of sync - requires 2048 bytes of I/O to SD card
  if ((millis() - syncTime) <  SYNC_INTERVAL) return;
  syncTime = millis();
  if (!file.sync())
     error("sync");
// Subroutines //
// FAT16Lib store error strings in flash to save RAM
void error_P(const char *str)
  PgmPrint("error: ");
  SerialPrintln_P(str);
  if (card.errorCode)
    PgmPrint("SD error: ");
    Serial.print(card.errorCode, HEX);
    Serial.print(',');
    digitalWrite(ledPinG, LOW);
  while(1);
// Get the time from the external clock
char* getClock(char *timeStr)
  char buffer[5]=" ";
  itoa(RTC.get(DS1307_HR,true),buffer,10); //Hours
  strcpy(timeStr,buffer);
  strcat(timeStr,":");
  itoa(RTC.get(DS1307_MIN,false),buffer,10); //Minutes
  if (strlen(buffer)==1)// Add 0 if a single digit minute has been returned
    strcat(timeStr,"0");
  strcat(timeStr,buffer);
  itoa(RTC.get(DS1307_SEC,false),buffer,10); //Seconds
  if (strlen(buffer)==1)// Add 0 if a single digit second has been returned
  return timeStr;
// Get the date from the external clock
char* getDate(char *dateStr)
    char buffer[5]=" ";
    itoa(RTC.get(DS1307_DATE,true),buffer,10);
    strcpy(dateStr,buffer);
    strcat(dateStr,"/");
    itoa(RTC.get(DS1307_MTH,false),buffer,10);
    strcat(dateStr,buffer);
    itoa(RTC.get(DS1307_YR,false),buffer,10);
    return dateStr;
Image:
