Yet another error: expected unqualified-id before numeric constant [SOLVED]
Hi guys and gals,
I’m working on an Arduino Uno R3 on Ubuntu 14.04 and am using Arduino IDE 1.0.5. Now I’m trying to get my WiFly shield talking through the SPI-UART bridge on it. I got the following code from Sparkfun.com:
 * WiFly UART-SPI bridge Example
 * Copyright (c) 2010 SparkFun Electronics.  All right reserved.
 * Written by Chris Taylor
 * This code was written to demonstrate the WiFly Shield from SparkFun Electronics
 * This code will initialize and test the SC16IS750 UART-SPI bridge, and allow
 * transparent communication with the device from a terminal.
 * http://www.sparkfun.com
#include <string.h> // Required for strlen()
// SCI16IS750 Registers
#define THR        0x00 << 3
#define RHR        0x00 << 3
#define IER        0x01 << 3
#define FCR        0x02 << 3
#define IIR        0x02 << 3
#define LCR        0x03 << 3
#define MCR        0x04 << 3
#define LSR        0x05 << 3
#define MSR        0x06 << 3
#define SPR        0x07 << 3
#define TXFIFO     0x08 << 3
#define RXFIFO     0x09 << 3
#define DLAB       0x80 << 3
#define IODIR      0x0A << 3
#define IOSTATE    0x0B << 3
#define IOINTMSK   0x0C << 3
#define IOCTRL     0x0E << 3
#define EFCR       0x0F << 3
#define DLL        0x00 << 3
#define DLM        0x01 << 3
#define EFR        0x02 << 3
#define XON1       0x04 << 3
#define XON2       0x05 << 3
#define XOFF1      0x06 << 3
#define XOFF2      0x07 << 3
// Arduino SPI pins
#define CS         10
#define MOSI       11
#define MISO       12
#define SCK        13
// Communication flags and variables
char incoming_data;
char TX_Fifo_Address = THR;
char clr = 0;
char polling = 0;
// SC16IS750 Configuration Parameters
struct SPI_UART_cfg
  char DivL,DivM,DataFormat,Flow;
struct SPI_UART_cfg SPI_Uart_config = {
  0x50,0x00,0x03,0x10};
  // Initialize SPI pins
  pinMode(MOSI, OUTPUT);
  pinMode(MISO, INPUT);
  pinMode(SCK,OUTPUT);
  pinMode(CS,OUTPUT);
  digitalWrite(CS,HIGH); //disable device
  SPCR = (1<<SPE)|(1<<MSTR)|(1<<SPR1)|(1<<SPR0);
  clr=SPSR;
  clr=SPDR;
  delay(10);
  Serial.println("\n\r\n\rWiFly Shield Terminal Routine");
  // Test SPI communication
  if(SPI_Uart_Init()){
    Serial.println("Bridge initialized successfully!");
  else{
    Serial.println("Could not initialize bridge, locking up.\n\r");
    while(1);
  // Poll for new data in SC16IS750 Recieve buffer
  if(SPI_Uart_ReadByte(LSR) & 0x01)
    polling = 1;
    while(polling)
      if((SPI_Uart_ReadByte(LSR) & 0x01))
        incoming_data = SPI_Uart_ReadByte(RHR);
        Serial.print(incoming_data);
        polling = 0;
  // Otherwise, send chars from terminal to SC16IS750
  else if(Serial.available())
    incoming_data = Serial.read();
    select();
    spi_transfer(0x00); // Transmit command
    spi_transfer(incoming_data);
    deselect();
char SPI_Uart_Init(void)
// Initialize SC16IS750
  char data = 0;
  SPI_Uart_WriteByte(LCR,0x80); // 0x80 to program baudrate
  SPI_Uart_WriteByte(DLL,SPI_Uart_config.DivL); //0x50 = 9600 with Xtal = 12.288MHz
  SPI_Uart_WriteByte(DLM,SPI_Uart_config.DivM);
  SPI_Uart_WriteByte(LCR, 0xBF); // access EFR register
  SPI_Uart_WriteByte(EFR, SPI_Uart_config.Flow); // enable enhanced registers
  SPI_Uart_WriteByte(LCR, SPI_Uart_config.DataFormat); // 8 data bit, 1 stop bit, no parity
  SPI_Uart_WriteByte(FCR, 0x06); // reset TXFIFO, reset RXFIFO, non FIFO mode
  SPI_Uart_WriteByte(FCR, 0x01); // enable FIFO mode
  // Perform read/write test to check if UART is working
  SPI_Uart_WriteByte(SPR,'H');
  data = SPI_Uart_ReadByte(SPR);
  if(data == 'H'){
    return 1;
  else{
    return 0;
void SPI_Uart_WriteByte(char address, char data)
// Write byte to register address on SC16IS750
  long int length;
  char senddata[2];
  senddata[0] = address;
  senddata[1] = data;
  select();
  length = SPI_Write(senddata, 2);
  deselect();
long int SPI_Write(char* srcptr, long int length)
// Send entire string to SC16IS750
  for(long int i = 0; i < length; i++)
    spi_transfer(srcptr[i]);
  return length;
void SPI_Uart_WriteArray(char *data, long int NumBytes)
// Send entire string to THR of SC16IS750
  long int length;
  select();
  length = SPI_Write(&TX_Fifo_Address,1);
  while(NumBytes > 16) // Split array into 16 character chunks
    length = SPI_Write(data,16);
    NumBytes -= 16;
    data += 16;
  length = SPI_Write(data,NumBytes);
  deselect();
char SPI_Uart_ReadByte(char address)
// Read from SC16IS750 register
  char data;
  address = (address | 0x80);
  select();
  spi_transfer(address);
  data = spi_transfer(0xFF);
  deselect();
  return data;
void SPI_Uart_println(char *data)
// Write string to SC16IS750 followed by a carriage return
  SPI_Uart_WriteArray(data,strlen(data));
  SPI_Uart_WriteByte(THR, 0x0d);
void SPI_Uart_print(char *data)
// Write string to SC16IS750, no carriage return
char spi_transfer(volatile char data)
  SPDR = data;                    // Start the transmission
  while (!(SPSR & (1<<SPIF)))     // Wait for the end of the transmission
  return SPDR;                    // return the received byte
void select(void)
  digitalWrite(CS,LOW);
void deselect(void)
Once I compiled the code, I get the following error:
WiFly_Terminal.ino:46:20: error: expected unqualified-id before numeric constant
/usr/share/arduino/hardware/arduino/variants/standard/pins_arduino.h:41:22: note: in expansion of macro ‘MOSI’
 static const uint8_t MOSI = 11;
WiFly_Terminal.ino:47:20: error: expected unqualified-id before numeric constant
/usr/share/arduino/hardware/arduino/variants/standard/pins_arduino.h:42:22: note: in expansion of macro ‘MISO’
 static const uint8_t MISO = 12;
WiFly_Terminal.ino:48:20: error: expected unqualified-id before numeric constant
/usr/share/arduino/hardware/arduino/variants/standard/pins_arduino.h:43:22: note: in expansion of macro ‘SCK’
 static const uint8_t SCK  = 13;
I have no way of really knowing why this happens because this is not because of the code, but because this code is part of the IDE itself. Anyone know how to combat this? I’ve tried running this on Arduino IDE 1.0.6, but I still get the same errors.
I’ve tried looking for answers on Google but nothing satisfactory.
Comment these defines out and it compiles.
#define MOSI       11
#define MISO       12
#define SCK        13
That worked. Thanks a lot!
