Yet Another "Serial Port Already in Use" Problem
Hi folks,
I’m still new to programming but thanks to a senior project I’m 6 months into I’ve had quite a bit of practice with my uno and mega boards. Recently I started having a problem come up - maybe after hours of successful uploading or sometimes with my first upload of the day - my sketches won’t upload and I get the error below. This includes my sketches and all of the standard examples as well. It’s not related to port/board settings as I don’t change them once I get rolling and once it starts none of my arduino compatible hardware will access a serial port. I restart the IDE and nothing changes, I restart the computer, fully shut down, log into different users… nothing works. After a day or to the problem goes away. I get some time in and suddenly the error starts up and I can’t do any work until it decides to go away. I’ve even taken the boards to other computers with the Arduino IDE and about 50% of the time they will work, the rest of the time they give the same error on the second computer. If I can get the board working on that second computer, when I bring it back to my main computer it sometimes works and sometimes doesn’t. I wish I could be more specific on the frequency but I haven’t been doing much more than frantically trying things.
I’ve googled extensively on this and read every thread on the matter including on windows computers. I don’t have any software (I know of) that is using my serial ports. I’ve tried running the “lsof | grep usbmodem” line (from http://arduino.cc/forum/index.php?topic=28487.0 thread) to see if anything is using my port (dev/tty/BrianJosephssMacPro-Blu) and nothing returns. I’ve tried Fix the serial port in use issue for Java/Arduino on OS X Lion. · GitHub and there is no change. I hope someone can help as this is a devastating setback every time it comes up. Not a lot of weeks left until graduation…
My computer: Mac OS 10.7.5
My Boards: Arduino Mega 2560 and Uno via Arduino IDE 1.0.4 ; Chipkit Uno32 via MPIDE
This is the error:
Binary sketch size: 18,368 bytes (of a 258,048 byte maximum)
processing.app.SerialException: Serial port ‘/dev/tty.BrianJosephssMacPro-Blu’ already in use. Try quiting any programs that may be using it.
at processing.app.Serial.(Serial.java:171)
at processing.app.Serial.(Serial.java:77)
at processing.app.debug.Uploader.flushSerialBuffer(Uploader.java:77)
at processing.app.debug.AvrdudeUploader.uploadViaBootloader(AvrdudeUploader.java:174)
at processing.app.debug.AvrdudeUploader.uploadUsingPreferences(AvrdudeUploader.java:67)
at processing.app.Sketch.upload(Sketch.java:1671)
at processing.app.Sketch.exportApplet(Sketch.java:1627)
at processing.app.Sketch.exportApplet(Sketch.java:1599)
at processing.app.Editor$DefaultExportHandler.run(Editor.java:2380)
at java.lang.Thread.run(Thread.java:680)
processing.app.debug.RunnerException: Serial port ‘/dev/tty.BrianJosephssMacPro-Blu’ already in use. Try quiting any programs that may be using it.
at processing.app.debug.Uploader.flushSerialBuffer(Uploader.java:101)
Serial port '/dev/tty.BrianJosephssMacPro-Blu' already in use.
That isn't a valid name for a Arduino board. Looks like you haven't selected the right serial port.
An official 2560 and Uno will show up as a "usbmodem". If the board has a FTDI chip (like a OSEPP knockoff) and you have FTDI drivers it will show up as "usbserial".
http://www.ajudino.com/2013/04/1-condigurando-sua-ide-arduino-para.html :)
James C4S,
You certainly respond to a lot of these type of issues, I’m honored you took the time! I think you must be right. In my poking and prodding I discovered that port name I listed above was a bluetooth port set up by my computer to talk to a smartphone. It was never the serial port I was using when programming was actually working. When I plug in my Mega or my Uno no new ports show up in the list of available ports. When I plug my Chipkit board in with MPIDE open I do get a new port there, but it doesn’t flinch when I plug the Arduino boards in, though it should.
So, I guess my problem gets reduced down to: Arduino IDE doesn’t recognize my boards when they are plugged. It certainly used to, I don’t know what changed. When they disappeared from the list I must have mistakenly picked the bluetooth port - which was already in use and never let the IDE get far enough to tell me that there was no board to communicate to.
Any thoughts on the missing ports? I downloaded FTDI drivers even though I read 10 times that I don’t need them…
Brian
bjosephs: Any thoughts on the missing ports? I downloaded FTDI drivers even though I read 10 times that I don't need them...
Where did you buy them from?
bjosephs: In my poking and prodding I discovered that port name I listed above was a bluetooth port set up by my computer to talk to a smartphone.
I've read several threads where disabling the Bluetooth driver from Device Manager fixed their issue. More than likely a bug with some Bluetooth drivers.
codlink:
The bluetooth issue applies to windows.
This user is on a Mac.
Folks,
Bad cable! I got so wrapped up in the "serial port" error I missed the fact that my board simply wasn't recognized... and I'd spent so long looking at complex explanations for that I missed the simple possibility that it might not be connected... the boards get power but no data transmission.
Switched cables and all is well now.
Brian
