YF-S201 Hall effect Flow Sensor help getting code to return a value.
I set up my YF-S201 flow meter with my Arduino Uno board and had it working fine.
I then tried to replicate it using a LoLin Node MCU V3 ESp 8266
I copied the code across and modified the interrupt function using ICACHE_RAM_ATTR to get it running OK.
However I am just getting 0 returned as the flowrate even if I blow through the meter.
Can anyone see where my code may be wrong for the device?
Code below:
Thanks
volatile int  flow_frequency;  // Measures flow meter pulses
unsigned int  l_hour;          // Calculated litres/hour
unsigned char flowmeter = D2;  // Flow Meter Pin number
unsigned long currentTime;
unsigned long cloopTime;
void ICACHE_RAM_ATTR flow ()                  // Interrupt function
   flow_frequency++;
   pinMode(flowmeter, INPUT);
   attachInterrupt(0, flow, RISING); // Setup Interrupt
                                     // see http://arduino.cc/en/Reference/attachInterrupt
   sei();                            // Enable interrupts
   currentTime = millis();
   cloopTime = currentTime;
void loop ()
   // Every second, calculate and print litres/hour
   if(currentTime >= (cloopTime + 1000))
      cloopTime = currentTime;              // Updates cloopTime
      // Pulse frequency (Hz) = 7.5Q, Q is flow rate in L/min. (Results in +/- 3% range)
      l_hour = (flow_frequency * 60 / 7.5); // (Pulse frequency x 60 min) / 7.5Q = flow rate in L/hour
      flow_frequency = 0;                   // Reset Counter
      Serial.print(l_hour, DEC);            // Print litres/hour
      Serial.println(" L/hour");
Are you sure D2 is interrupt 0?
Why don't you use the digitalPinToInterrupt() function there instead, as explained a.o. here?
