Hi everyone, I am using YFS201 Hall Effect Water Flow Sensor with ESP8266 to calculate the volume of the water but its not giving accurate values.
I have changed the calibration factor many times but its giving different values withe same value of calibration factor.
float calibrationFactor = 7.5;
Here is my code
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SH110X.h>
#define i2c_Address 0x3c //initialize with the I2C addr 0x3C
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
#define OLED_RESET -1 // Reset pin # (or -1 if sharing Arduino reset pin)
Adafruit_SH1106G display = Adafruit_SH1106G(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
#define SENSOR 14
long currentMillis = 0;
long previousMillis = 0;
int interval = 1000;
volatile byte pulseCount;
byte pulse1Sec = 0;
float flowRate;
unsigned long flowMilliLitres;
unsigned int totalMilliLitres;
float flowLitres;
float totalLitres;
long wakeup = 0;
void IRAM_ATTR pulseCounter()
pulseCount++;
delay(250); // wait for the OLED to power up
display.begin(i2c_Address, true); // Address 0x3C default
//display.setContrast (0); // dim display
// display.display();
// delay(2000);
display.clearDisplay();// Clear the buffer.
delay(10);
pinMode(SENSOR, INPUT_PULLUP);
pulseCount = 0;
flowRate = 0.0;
flowMilliLitres = 0;
totalMilliLitres = 0;
previousMillis = 0;
digitalWrite(SENSOR, HIGH);
attachInterrupt(digitalPinToInterrupt(SENSOR), pulseCounter, RISING);
currentMillis = millis();
if (currentMillis - previousMillis > interval)
//noInterrupts();
pulse1Sec = pulseCount;
pulseCount = 0;
//interrupts();
// Because this loop may not complete in exactly 1 second intervals we calculate
// the number of milliseconds that have passed since the last execution and use
// that to scale the output. We also apply the calibrationFactor to scale the output
// based on the number of pulses per second per units of measure (litres/minute in
// this case) coming from the sensor.
flowRate = ((1000.0 / (millis() - previousMillis)) * pulse1Sec) / calibrationFactor;
previousMillis = millis();
// Divide the flow rate in litres/minute by 60 to determine how many litres have
// passed through the sensor in this 1 second interval, then multiply by 1000 to
// convert to millilitres.
flowMilliLitres = (flowRate / 60) * 1000;
flowLitres = (flowRate / 60);
// Add the millilitres passed in this second to the cumulative total
totalMilliLitres += flowMilliLitres;
totalLitres += flowLitres;
// Print the flow rate for this second in litres / minute
Serial.print("Flow rate: ");
Serial.print(float(flowRate)); // Print the integer part of the variable
Serial.print("L/min");
Serial.print("\t"); // Print tab space
display.setCursor(10,0); //oled display
display.setTextSize(1);
display.setTextColor(SH110X_WHITE);
display.print("Water Flow Meter");
display.setCursor(0,20); //oled display
display.setTextSize(2);
display.print("R:");
display.print(float(flowRate));
display.setCursor(100,28); //oled display
display.print("L/M");
// Print the cumulative total of litres flowed since starting
Serial.print("Output Liquid Quantity: ");
Serial.print(totalMilliLitres);
Serial.print("mL / ");
Serial.print(totalLitres);
Serial.println("L");
display.setCursor(0,45); //oled display
display.print("V:");
display.print(totalLitres);
display.setCursor(100,53); //oled display
display.print("L");
display.display();
Here is my setup
Anyone please help why I am not getting the accurate values.
Regards
RJ
