Hello, I was trying to program an ATtiny85 with an Arduino uno as ISP. This ATtiny was already use by me in the past without problems, but today when I try to upload the sketch i found this error
Arduino:1.8.10 (Windows 10), Scheda:"ATtiny25/45/85, ATtiny25, Internal 1 MHz"
Lo sketch usa 672 byte (32%) dello spazio disponibile per i programmi. Il massimo è 2048 byte.
Le variabili globali usano 9 byte (7%) di memoria dinamica, lasciando altri 119 byte liberi per le variabili locali. Il massimo è 128 byte.
C:\Users\Claxl\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\Claxl\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -pattiny25 -cstk500v1 -PCOM3 -b19200 -Uflash:w:C:\Users\Claxl\AppData\Local\Temp\arduino_build_177403/Blink.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\Claxl\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM3
Using Programmer : stk500v1
Overriding Baud Rate : 19200
AVR Part : ATtiny25
Chip Erase delay : 4500 us
PAGEL : P00
BS2 : P00
RESET disposition : possible i/o
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 6 4 0 no 128 4 0 4000 4500 0xff 0xff
flash 65 6 32 0 yes 2048 32 64 4500 4500 0xff 0xff
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
Programmer Type : STK500
Description : Atmel STK500 Version 1.x firmware
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x000000 (retrying)
Errore durante il caricamento dello sketch
avrdude: Yikes! Invalid device signature.
Double check connections and try again, or use -F to override
this check.
avrdude done. Thank you.
Questo report potrebbe essere più ricco di informazioni abilitando l'opzione
"Mostra un output dettagliato durante la compilazione"
in "File -> Impostazioni"
I've triple checked the cable connection, also used this as packed for insert the ATtiny85 in the Arduino 1.8.2 IDE.
Any solutions? I've never flash it by Clock : "External x Mhz", only with internal. I've used a 0.10uf condensator and taste it with a multimeter
