I recently purchased a funduino mega 2560 and when i tried to upload to it any sketch I got receive timout error, while whenever i plugged it in the L and on LED just turn on solid no flashing no nothing so i guessed it had to do something with the bootloader. I tried to burn the bootloader to it and while i followed the steps on: burn bootloader to mega 2560 with and UNO ISP (SOLVED) - Installation & Troubleshooting - Arduino Forum and did the proper wiring but i got the error avrdude: Yikes! Invalid device signature. Double check connections and try again, or use -F to override this check. with a signature of all 0s. The interesting part of the error is that Oscillator is set to OFF does that has something to do with the errors? I really tried everything and read a lot of threads in this forum with no result at all...
The Error:
Arduino: 1.6.12 (Windows 10), Board: "Arduino/Genuino Uno"
C:\Users\chs\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino6/bin/avrdude -CC:\Users\chs\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino6/etc/avrdude.conf -v -patmega328p -cstk500v1 -PCOM7 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0x05:m -Uhfuse:w:0xDE:m -Ulfuse:w:0xFF:m
avrdude: Version 6.3, compiled on Sep 12 2016 at 17:24:16
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\chs\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino6/etc/avrdude.conf"
Using Port : COM7
Using Programmer : stk500v1
Overriding Baud Rate : 19200
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : STK500
Description : Atmel STK500 Version 1.x firmware
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.03s
avrdude: Device signature = 0x000000 (retrying)
Reading | ################################################## | 100% 0.02s
Error while burning bootloader.
this check.
avrdude done. Thank you.
option enabled in File -> Preferences.
Error.txt (3.65 KB)
