Your latest purchase
Hi Whandalll, The curiosity nano looks interesting, particularly if you need a debugger. Have you used the microchip ide with it, I presume the debugging side of it would not work with arduino ide, although I think it has a boot-loader installed. so may be programmable via arduino ide (Or is this a new purchase to try it out, - with the discount it's a reasonable price, but cheap for development kit.)
Exactly these two are still in the mail, I had no chance to play with them yet.
Thanks
$7.97 USD.
2.54mm 100sets of connectors SM 3Pin Pitch Female Male terminals SM-3P SM-3R JST
3 pin JST set X100
just got some as well, also some 8 pin sets.
Qdeathstar: just got some as well, also some 8 pin sets.
Do you have a link to the 8 pin?
sorry, these are jst xh
https://www.amazon.com/gp/product/B01IZALABE/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&psc=1
just got free samples high quality from Hammond Manufacturing. Got to love it!!!!!!!!!!
Too old, hands cold.
Can still use the iPad :)
Plus you are polishing the surface.
Stocking up, got a selection of colours, 24AWG.
https://www.ebay.com/itm/UL-Strand-Wire-14-16-18-20-22-24-26-28-30awg-Silicone-Flexible-Cables-Coloured/183867888930?var=691533739837&hash=item2acf615522:g:iAsAAOSwkCddGr1C
raymw: Some MBR0520L to see if i can actually work with stuff that small. I ordered some from ebay, a week or two ago. I've no idea what they sent, nor did they, they wouldn't send the correct items as advertised, so I got my money back, and ordered via Amazon, and they are the correct diodes. 40 from a seller on Amazon was cheaper than via Farnel incl. postage. I only need a few, most will be dropped on the floor, I expect. I've been with ebay for years, don't buy much, but recently I've had 3 out of six orders go bad, and I try to assess the quality of the supplier, not just their star ratings.
After wating for the stars to align and the wind to change, I tried soldering one of the diodes to the Nano pcb this morning. Not having the set-up that I had before, I managed to position the chip, using a scriber, but the liquid flux surface tension stuck the chip to the scriber point. My soldering iron tip is far, far too big, and I had to use a 10x jeweller's loupe to see what I was doing. After a few attempts, however, I finally soldered it, and the Nano now seems to work via usb. Not financially, or otherwise worth the effort, but quite chuffed that I managed it - and I can rinse and repeat 39 more times, since I never lost any diodes...
^^ if you had the right stuff already (magnifying glass workbench and fine tipper soldering iron), this would have been easy work. And yes I would spend some time salvaging cheap Nanos by replacing bad diode.
RF-Nano
BLE-Nano
Never seem to have enough small storage containers. 50 for $4.30 USD
https://www.ebay.ca/itm/10-30-50x-Round-Empty-Plastic-Cosmetic-Pot-Jar-Tin-Container-Sample-Box-Portable/254293826390?_trkparms=aid%3D1110001%26algo%3DSPLICE.SIM%26ao%3D2%26asc%3D20160323102634%26meid%3Dd2bcc73d431849c682df80e1abc1bde4%26pid%3D100623%26rk%3D4%26rkt%3D6%26sd%3D254293826919%26itm%3D254293826390%26pmt%3D0%26noa%3D1%26pg%3D2047675&_trksid=p2047675.c100623.m-1
I just bought 250 plastic shot classes
I have heard that the shot class can cause memory problems.
groundFungus: I have heard that the shot class can cause memory problems.
Gives me a ringing in my ears and an unpleasant burning smell :)
...R
A metal sign I bought recently for 1€.
i use them for mixing epoxy and the like.
