zoomx:
A cheap board already exists, the only difference is that it uses a PIC. But I believe that a Arduino kit is interesting too, many people request Atmega328 because they can mod it. But I believe that there is a better solution.
There are kits that uses an STM32F103 that has alread an Arduino core (see http://stm32duino.com there are 3 cores!) for example the DSO138 cheap cheap oscilloscope. The MCU is also cheap and has 5volt tolerant pin but it is a Cortex-M3.
I believe that people that ask for an Atmega328 can use an STM32F103 too. STM32F103 is faster, has more pins, more flash, more ram and has DMA.
Hello zoomx,
For what I saw until today with the 3 prototypes I built the processing capability of the Atmega328 is enough. Even thought the program tests a couple of things continually (like the power voltage) it does not impact the precision. So I don't really need to upscale the microcontroller. All the more that as you said, people know the Atmega328 and want it. After all this makes the board programmable as a UNO board.
Anyway I would consider upgrading to cortex m0 because 1) it has built in USB 2) It is clocked at 32 Mhz max or with PLL multiply up to 96 Mhz. This would give an advantage in time resolution for low frequency period measurement using FreqMeasure library. But I don't know if the PLL clock will be stable enough. I don't think so but I will try on an Arduino M0 board. Anyway 32 Mhz would still be a little better than 16 Mhz.
But, once again, from the first results of the survey, some people want the Atmega328, most don't mind and very few ask for the cortex m0.
A big problem I face is for amplifying the signal over the very broadband of 5Hz to 100 Mhz. This is different than the amplification problem of VHF or UHF narrow "band". I try to achieve this with only one circuit, otherwise it is going to be expensive, complicated and with a large footprint.
It is all the more complicated with a 5 v USB voltage source (from 4,75 v minus maybe a diode etc) so it really cannot power an amplifier in the tens of megahertz range (impedances in the few hundred ohms) and it draws some current.
All in all the first design is, I believe, good to very good but I didn't include a USB port considering this is not a board that would be programmed often and the SPI port would suffice. But it seems most users really like the concept of the USB port + power. This is the new big problem.
