While working up this thread Switch/case style this unhelpful message showed up at least five times. Is there some way to make it appear only once - or never?
It's annoying, because it tends to pop up while you are writing and its masks the preview window unless you dismiss it. In your case, since "switch/case" probably appears in many threads, you got a lot of popups.
I noticed that the popup messages are more influenced by the title than by the text body. One workaround that usually works for me is to write the text first and add the title last.
Hmmm. I'll try that!
