Hi there, this is my first post to the forum. I have a bit of experience using the Uno, but not so much with the Yún.
I'm having an issue where my sketch works in the Uno but not on the Yún. I am basically trying to get my Grove ear clip heart rate sensor to run on the Yún. It should calculate my heart rate over 20 seconds, and then display the result when I get the data from the Yún. I don't think the sketch even begins running though. I am using the attachInterrupt function and attaching the sensor to digital pin 2.
I am using a modified version of this sketch: http://www.seeedstudio.com/wiki/Grove_-_Heart_rate_ear_clip_kit
Any help would be greatly appreciated. Thanks much!!
#include <Bridge.h>
#include <Console.h>
#include <FileIO.h>
#include <HttpClient.h>
#include <Mailbox.h>
#include <Process.h>
#include <YunClient.h>
#include <YunServer.h>
// LED
int LED = 13;
//state of LED, each time an external interrupt
// will change the state of LED
boolean led_state = LOW;
// Heart rate variables
unsigned char counter;
unsigned long temp[21];
unsigned long sub;
bool data_effect = true;
//the measurement result of heart rate
unsigned int heart_rate;
// you can change it follow your system's request.
// 2000 meams 2 seconds. System return error
// if the duty overtrip 2 second.
const int max_heartpluse_duty = 2000;
YunServer server;
String startString(8080);
pinMode(LED, OUTPUT);
// Initialize serial communication
Bridge.begin();
// Listen for console logging
Console.begin();
while (!Console) {
; // wait for console port to connect
Console.println("Please ready your heart rate sensor.");
// Listen for incoming connection only from localhost
// (no one from the external network could connect)
server.noListenOnLocalhost();
server.begin();
arrayInit();
Console.println("Heart rate test begin.");
// set interrupt 1, digital port 2
attachInterrupt(1, interrupt, RISING);
// Get clients coming from server
YunClient client = server.accept();
// Is there a new client?
if (client) {
client.setTimeout(5);
// Process request
// read the command
String command = client.readString();
// kill whitespace
command.trim();
Console.println(command);
// API command Get Heart Rate values
if (command == "getheartrate") {
client.println("Status:200");
client.println("Content-Type: application/javascript");
client.println();
Console.print("Heart_rate_is:\t");
Console.println(heart_rate);
// Close connection and free resources.
client.stop();
delay(50); // Poll every 50ms
// Function: calculate the heart rate
void sum()
if(data_effect)
heart_rate=1200000/(temp[20]-temp[0]);//60*20*1000/20_total_time
data_effect=1;//sign bit
// Function: Interrupt service routine. Get the sigal from the external interrupt
void interrupt()
temp[counter]=millis();
Console.println(counter,DEC);
Console.println(temp[counter]);
switch(counter)
case 0:
sub=temp[counter]-temp[20];
Console.println(sub);
default:
sub=temp[counter]-temp[counter-1];
if(sub>max_heartpluse_duty) // set 2 seconds as max heart pluse duty
data_effect=0; // sign bit
counter=0;
Console.println("Heart rate measure error, test will restart!" );
arrayInit();
if (counter==20&&data_effect)
counter=0;
sum();
else if(counter!=20&&data_effect)
counter++;
counter=0;
data_effect=1;
// Function: Initialization for the array(temp)
void arrayInit()
for(unsigned char i=0;i < 20;i ++)
temp[i]=0;
temp[20]=millis();
