Hello,
Thank you for your answer and sorry for the late reply. I’ve been testing but had no luck. Let me elaborate on what I did.
First, I had a 3.3V Pro Mini with RFM69W and a 5V Uno (with logic level convertor) with RFM69W send messages to one another. This works OK for sending and receiving. This way, I’m sure my sketches are allright.
Then I replaced the Uno with a Yun, indeed using Pin 3 now and using ICSP (as described in the Sparkfun tutorial)
(see for sketch and wiring scheme)
I have no problem uploading the sketch, the thing is that I cannot send/receive any messages to/from the Yun.
(communication with ProMini to/from Yun does not work)
(communication with ProMini to/from Uno does work)
P.S. I used is wiring scheme RFM69HCW because couldn’t find RFM69W)
#include <RFM69.h>
#include <SPI.h>
// Addresses for this node. CHANGE THESE FOR EACH NODE!
#define NETWORKID 0 // Must be the same for all nodes
#define MYNODEID 2 // My node ID
#define TONODEID 1 // Destination node ID
// RFM69 frequency, uncomment the frequency of your module:
#define FREQUENCY RF69_433MHZ
//#define FREQUENCY RF69_915MHZ
// AES encryption (or not):
#define ENCRYPT false // Set to "true" to use encryption
#define ENCRYPTKEY "TOPSECRETPASSWRD" // Use the same 16-byte key on all nodes
// Use ACKnowledge when sending messages (or not):
#define USEACK false // Request ACKs or not
// Packet sent/received indicator LED (optional):
#define LED 9 // LED positive pin
#define GND 8 // LED ground pin
// Create a library object for our RFM69HCW module:
RFM69 radio;
// Open a serial port so we can send keystrokes to the module:
while (!Serial);
Serial.print("Node ");
Serial.print(MYNODEID,DEC);
Serial.println(" ready now");
Serial.println(RF69_IRQ_PIN,DEC);
Serial.println(RF69_IRQ_NUM,DEC);
// Set up the indicator LED (optional):
// pinMode(LED,OUTPUT);
// digitalWrite(LED,LOW);
// pinMode(GND,OUTPUT);
// digitalWrite(GND,LOW);
// Initialize the RFM69HCW:
radio.initialize(FREQUENCY, MYNODEID, NETWORKID);
//radio.setHighPower(); // Always use this for RFM69HCW
// Turn on encryption if desired:
if (ENCRYPT)
radio.encrypt(ENCRYPTKEY);
// Set up a "buffer" for characters that we'll send:
static char sendbuffer[62];
static int sendlength = 0;
// SENDING
// In this section, we'll gather serial characters and
// send them to the other node if we (1) get a carriage return,
// or (2) the buffer is full (61 characters).
// If there is any serial input, add it to the buffer:
if (Serial.available() > 0)
char input = Serial.read();
if (input != '\r') // not a carriage return
sendbuffer[sendlength] = input;
sendlength++;
// If the input is a carriage return, or the buffer is full:
if ((input == '\r') || (sendlength == 61)) // CR or buffer full
// Send the packet!
Serial.print("sending to node ");
Serial.print(TONODEID, DEC);
Serial.print(", message [");
for (byte i = 0; i < sendlength; i++)
Serial.print(sendbuffer[i]);
Serial.println("]");
// There are two ways to send packets. If you want
// acknowledgements, use sendWithRetry():
if (USEACK)
if (radio.sendWithRetry(TONODEID, sendbuffer, sendlength))
Serial.println("ACK received!");
Serial.println("no ACK received");
// If you don't need acknowledgements, just use send():
else // don't use ACK
radio.send(TONODEID, sendbuffer, sendlength);
sendlength = 0; // reset the packet
Blink(LED,10);
// RECEIVING
// In this section, we'll check with the RFM69HCW to see
// if it has received any packets:
if (radio.receiveDone()) // Got one!
// Print out the information:
Serial.print("received from node ");
Serial.print(radio.SENDERID, DEC);
// The actual message is contained in the DATA array,
// and is DATALEN bytes in size:
for (byte i = 0; i < radio.DATALEN; i++)
Serial.print((char)radio.DATA[i]);
// RSSI is the "Receive Signal Strength Indicator",
// smaller numbers mean higher power.
Serial.print("], RSSI ");
Serial.println(radio.RSSI);
// Send an ACK if requested.
// (You don't need this code if you're not using ACKs.)
if (radio.ACKRequested())
radio.sendACK();
Serial.println("ACK sent");
//Blink(LED,10);
void Blink(byte PIN, int DELAY_MS)
// Blink an LED for a given number of ms
digitalWrite(PIN,HIGH);
delay(DELAY_MS);
digitalWrite(PIN,LOW);
