Yun and SD Card fileIO.Write() overwrites entire file
Hello!
I'm trying to figure out a small issue I have. On the Arduino Yun, when I write to an SD card with the card in FILE_WRITE, It deletes the entire contents of the card, except for what I wanted to write. However, it writes it in the correct spot. Here is my code.
void addCard()
  boolean addRoutine = true;
  digitalWrite(readEnable, LOW);
  int value = 0;
  String currentCard;
  boolean cardStatus = false;
  flushBuffers();
  while(addRoutine == true)
    blinkGBLED();
    if(rfidSerial.available() > 0) // Waits for something to come on the serial line
      if((value = rfidSerial.read()) == 10) // check for header [Header of data = 10]
        cardStatus = false;
        currentCard = getCardID(); // Get the ID, sets readCard = to the read ID
        if(currentCard == Master)
          clearLED();
          blinkRedLED();
          addRoutine = false;
          Console.println("Exiting Add Routine");
        else if ((currentCard == Delete)||(currentCard == Add))
          clearLED();
          blinkRedLED();
          addRoutine = false;
          Console.println("invalid card. Add or delete card. Exiting add routine");
          if(cardFind(currentCard)>0)
          cardStatus = true;
          if(cardStatus == false)
            if(cardFind(Empty)>0)
              int startingSpot = cardFind(Empty);
              Console.println(startingSpot);
              File cardFile = FileSystem.open("/mnt/sd/Cards.txt", FILE_WRITE);
              if(startingSpot == 1)
              cardFile.seek(0);
              cardFile.seek((startingSpot-1)*12);
              Console.println(cardFile.position());
              unsigned int bufferLength = 11;
              char test23[11];
              currentCard.toCharArray(test23,bufferLength);
              [color=yellow]cardFile.write((byte*)test23,bufferLength);[/color]
              cardFile.close();
              Console.println("card added at spot " + startingSpot);
            if(cardFind(Empty)==0)
              File cardFile = FileSystem.open("/mnt/sd/Cards.txt", FILE_APPEND);
              cardFile.println(currentCard);
              cardFile.close();
              Console.println("card added to the end");
                     //Enter Key into Access List Slot
                clearLED();
                digitalWrite(passPin,HIGH);
                delay(1500);
          if(cardStatus == true)
            clearLED();
            digitalWrite(failPin,HIGH);
            delay(1500);
What I am doing is storing the ID's of some RFID tags on the SD Card. Cardfind() is a routine to find what line the card is located on the SD card, and returns that line number.
What I want to do, is if there is a card in the list with all 0's, (a card consists of 10 Hex values) I want to replace that with a good card. I can find that empty spot and seek to it, but when I start writing to it, It writes the information for the card I wanted, but deletes everything else from the card.
What I don't want to do is each time I want to add a card to the middle, I don't want to have to go through the entire file of cards and re-write the entire file.
Any assistance would be greatly appreciated!
A preview of the card file before and after the addition of one card in the middle:
0200805889
0200805888
0200805887
0000000000
0200805886
                                    0200805BB9 0200805BB9
Are you sure it is actually doing this ?
It's fairly normal, that when you write to a file, it deletes the existing file with that name, and starts writing a completely new file with the same name. That's the default behavior of most file systems.
It would be a different abnormal problem, if it also deleted any other files on the card, with different file names.
If you are only trying to use a single file, this might seem to be an obscure distinction.
mjw51881:
Even though that would be the smart and normal thing to do. Don't be scared because it looks like extra work, the microcontroller will do it all for you in a matter of milliseconds.
Thank you both for the insight. I guess most of all I was trying to help prevent redundant or extra work for the board as I want to add a web interface to this as well, but the re-writing of the entire file looks unavoidable.
