swaroop2011:
::::SNIP::::
If possible can you give a toy program for 2 devices which i can run and see if this thing works.
Toy program can be just setting up static ip address and sending a number. Other arduino will detect incoming byte and display the number.
Do we need to disable Dhcp or something ? If yes then how ?
::::SNIP::::
@jesse I tried out those recipes but it didn’t worked out for me.
3) Where do I need to exactly run that recipe code ?
4) Or else can you please provide a toy code as mentioned in above text ?
Thank you.
On #1, we do not have “toy programs”. We have tools.
There are many tools to see what is running.
On #2, maybe - but SonnyYu should answer that question as the link I provided is his.
On #3, again SonnyYu should help.
On #4, …
I think it would be good for you to go through some tutorials and some of the tools needed. Here is an explanation.
= [Q:] I cannot connect to My Arduino Yún. What do I do? =
First it’s good to know, when Arduino Yun cannot find the AP you have set it for (like your home wifi), it has a script that puts it back into default SSID and AP mode.
Next, you may have already watched this video, but it’s worth watching again. Pay extra attention to the part with the sketches.
Getting started with Arduino Yún - tutorial (6:53)
Then, read these short instructions. We (the volunteer support group) already know these steps by heart, so be familiar with the different reboot methods, and especially the 30+ second wifi reset. Also, not mentioned on that page, if you reset the Wifi/Linux part of the Yun, it will take from 2-8 minutes for the reboot. Lastly on this part, YOU MUST WAIT for the Linux portion to fully boot BEFORE YOU PRESS ANY of the REST buttons.
Resetting the processors (AR9331, WiFi, and 32U4)
‘’‘Then start over’’’, plug your Yun into the USB port, run this sketch, and hit the ‘‘Wifi Reset button’’ (for 5-10 seconds).
The YunSerialTerminal provides a simplified console access to the Linux part of the Yun. It works via the USB port (the one that powers the Yun - the microUSB). From there you’ll be able to run a few commands to give us a better idea of problems.
Also, be ready with this sketch YunWiFiStatus. This sketch will help us see the status of your home AP. The sketch prints the wifi status to the console every 5 seconds or so. This sketch might seem familiar as it was in that first video link (above).
Lastly, you should read this section on use the Linux CLI. You do not need to understand it right now, but it is good to read.
Let us know how it goes.
Post results from the YunSerialTerminal, if you are still having problems.
Please use markup when posting results. (See image below
Jesse
