Yun http:// web server showing older version (non-current) of SD card contents
Either I am misunderstanding something or I have a strange problem.
Via http:// my Yun is showing the files and layout from a previous (older) SD card layout. The files had been copied to the sd card using a pc not via the arduino ide.
I then used the pc to reformatted the sd card and put it back in the Yun and the Yun still showed the old file/folder layout.
Next I added different folders and files onto the SD card (using pc) then put it back in the Yun and it still shwos the old layout.
Cleared my browser cache. No difference.
Switched the yun off (pulled the power), reboot and still showing the old file/folder structure via http://myyun.local/sd
If I pull the sd out of the Yun then try to browse the http:// I get a long pause and finally and error (as expected)
So it seems the Yun is recognizing the SD card but has cached the contents somewhere?
Can anyone help please. If there an easy way to clear the web server cache?
Thank you in advance.
Maybe too simple, but have you already restarted your Yun?
BTW: I have never encountered such a problem.
It sounds like the SD is never getting written to when you are changing things on the PC. Are you unmounting (ejecting, safely removing, whatever your OS calls it)? If you make changes, remove the SD from the PC, reboot the PC, reinsert the SD, does the PC show the "new layout"?
