Yun is possible to change wifi Networks
how can it be done?
lets say.
that I have my home wifi setup.
then go to new place with wifi network
how can I change the wifi + password
how can it be done?
lets say.
If I understand correctly, you want to know how to switch to a different network when you travel? I would imagine you connect to your YUN's default IP (e.g.: mine is 192.168.240.1) then configure the network settings as you did with your home setup. Tell me if this is not what you want and I will help the best I can.
Thanks
and Yes that is my Q?
How would I get an Ip if I have not join a wifi- network ?
This is from the YUN's webpage:
WLAN RST. This button has a double feature. Primarly serves to restore the WiFi to the factory configuration. The factory configuration consist to put the WiFi of the Yún in access point mode (AP) and assign to it the default IP address that is 192.168.240.1, in this condition you can connect with your computer to the a WiFi network that appear with the SSID name "Arduino Yun-XXXXXXXXXXXX", where the twelve 'X' are the MAC address of your Yún. Once connected you can reach the web panel of the Yún with a browser at the 192.168.240.1 or "http://arduino.local" address.
